Hi allI have a little strange problem:On my notebook (Windows 8, 1920x1080) not all the text of my explorerbar items are shown,as you can see in the attached picture.It does not make any difference how wide the explorerbar is.Thanks and kind regardsFrank Uray
Could you please let me know the exact version and service release of Infragistics components that you are using and also it seem that you have applied isl file in order to style your application, could you please provide me this isl file.
I am waiting for your feedback.
And just as a hint: On my desktop PC (Windows 8), everything works fine.
I have tested your issue with Infragistics 13.2 service releases 2016 and 2023 (the latest service release) on a Windows Surface Tablet with Windows 8.1 pro (x64 screen resolution 1920x1080) with the attached sample and I was not able to reproduce this on my side. Could you please verify if your issue is reproducible with my sample on your environment, if it is not please update my sample in order to reproduces your issue. Also please let me know if you are able to reproduce this only in debug mode or if you run the exe.
Hi HristoWell, its strange ...I have tried to make a text project with setting the explorerbar as I do in the real application,and I am unable to reproduce the problem.Only in my real application this happens, it does not matter if in debug mode or not.There is something going on with the resolution, I have seen the form text of the mdi child formis different (resolution) than the form text of the mdi container form.Do you have any idea what can cause something like that ?It does not matter how wide I make the explorerbar, the text of the item is always cut off,even at runtime when I slide the splitter to make it wider.Thanks and best regardsFrank
I am just checking about the progress of this issue. Let me know If you need any further assistance on this issue?
Hi HristoThank you for your message.Well, the issue is still there and I have no plan why and how to find out whats the problem ...
Best regardsFrank Uray
In order to narrow if it is something related to some setting of your solution file or project file or form, I suggest you to try to reproduce this issue in separate from in the same project and try to reproduce the issue in another project in same solution. So if you are able to reproduce the issue in the same project and not in the other then the issue is related to something of your project settings and etc. On this why you will have direction where you should search for the root of the issue.
I hope that this will helps you.
