I would like to apply color on my background records depending on the 'Type' cell value
example : The lines where the 'Type' cell value is 'Réunion' must have a red backround
Dim HT As New Hashtable() Query.GetHTColors(HT) ' Get the hashtable where each type is associated with a color Dim MyBrush As New SolidColorBrush() For Each Rec As Infragistics.Windows.DataPresenter.DataRecord In Me.XamDataGrid_CRA.Records If Not IsDBNull(HT(Rec.Cells("Type").Value)) Then MyBrush = New SolidColorBrush(CType(ColorConverter.ConvertFromString(HT(Rec.Cells("Type").Value)), Color)) Else MyBrush = Brushes.White End If '' '' How to apply MyBrush on the background ??? (here) '' Next
Next
I have tried everything ... HELP
Becquet.Steve
Hello Steve,
I have been looking into your issue and can suggest using a Style with a DataTrigger like this one:
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Style.Triggers>
<DataTrigger Binding="{Binding Path=Record.Cells[2].Value,RelativeSource={RelativeSource Mode=Self}}" Value="Réunion">
<Setter Property="Background" Value="Red" />
</DataTrigger>
</Style.Triggers>
</Style>
in order to get a consistent behavior.
Please let me know if you require any further assistance on the matter.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hi Petar,
Thanks for your fast answer !!
All my 'Type colors' are in the hashtable HT and may change, i can also add new types and change their colors (stored in a SQL DB).
So, i would like to apply the background programmatically with VB and not XAML ...
I saw a few things about DataPresenter.DataRecordPresenter.FromRecord(...).Background= ...
But I don't know how to integrate it in my code :(
I see what you mean. What you can do is use a DynamicResource instead the static value, I have provided for the sample snippet, like so:
<Setter Property="Background" Value="{DynamicResource MyHashValue}"/>
And initially set it in code:
this.Resources.Add("MyHashValue", new SolidColorBrush(Colors.Red));
and switch it like so:
this.Resources.Remove("MyHashValue");
this.Resources.Add("MyHashValue", new SolidColorBrush(Colors.Aqua));
You can also reference this link: http://msdn.microsoft.com/en-us/library/ms750613.aspx to see if there is more suited approach for you.
Hope this helps.
Regards Petar.
I finally found, programmatically, how to access the datapresenter of a row without binding.
Like this :
For Each Rec In XamDataGrid_Adh.Records
Dim dp As Infragistics.Windows.DataPresenter.DataRecordPresenter = Infragistics.Windows.DataPresenter.DataRecordPresenter.FromRecord(Rec)
Dim MyBrush = [...] 'select the color with a converter
dp.Background = MyBrush
and use it in a refresh() function !
Hi Tyr,
I was trying your way to change the records background. Thing is, dp is always a null reference.
Any idea about the problem here ?
PS: I'm using XamDataGrid with custom object as DataSource.
Thanks.
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I created a sample project for you following your scenario and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
