I am using <igtbl:UltraGridColumn>
Now, I want to know how to select all rows at a time using a header checkbox.
Please do needful ASAP.
Hello Moulika,
Here is a link from our documentation that explains step by step how to add a template column in the UltraWebGrid:
http://help.infragistics.com/Doc/ASPNET/2011.1/CLR4.0/?page=WebGrid_Using_Column_Templates.html
Then if you want to make all rows selected using header checkbox template, you may handle the click event of the checkbox control and use the client-side API of UltraWebGrid to make all rows selected as shown here:http://help.infragistics.com/Help/Doc/ASPNET/2011.1/CLR4.0/html/WebGrid_Select_a_Row_on_the_Client_Side.html
Please note also that "SelectTypeRowDefault" property should be set to "Extended" in order multiple row selection.
I'm attaching you a sample with similar scenario for your reference.
Sincerely,
Tsanna
