Hello!
I'm using XamDateTimeInput to input data, but I can't bind it to event or trigger in order to close expanded calendar when clicking mouse. There is no events, mouse click on any place triggers no events. Is there any built in property for XamDateTimeInput that collapses it on click outside of the calendar?
Hello Igor,
Hi!
Thank you for the reply. I couldn't launch your application, probably we are using not latest infagistics libraries.
I had a long holiday, so I'm still working on this problem, I'll let you know when I find a solution. I'll try to edit question, because now it seems confusing to me, I'm surprised that you get what I asked.
Regards
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
I'm going to postpone solving this problem for two weeks, I'll let you know if there are new questions. Thanks for help
I am looking forward to hear from you.
Hello!I've tested several options with running your application, it seems that in your application there is no such a problem, because only 1 element is active at the moment. In your application, when inactive xamDateInput doesn't have dropdown button visible. But in our case we use other interface (look pic) and get this kind of error, cause dropdown button is visible and active. Please suggest, what properties should i check in order to fix this.
I have been looking into the screenshot you attached, but since I am not able to reproduce this on my side, I am not able to conclude what can cause this behavior. Could you please send us an isolated sample project where this is reproduced, so we could be able to investigate this further for you.
Hello!I didn't succeed making isolated project to repeat this bug, we will leave it for a while unsolved.
Please could you tell where can i predefine culture info for elements that use infragistics? I don't want calendar to be in hebrew but i can access it only from local machine settings.
Igor
You can use the following code, where "xdti" is the name of the XamDateTimeInput:
xdti.Dispatcher.Thread.CurrentCulture = new System.Globalization.CultureInfo("de-DE", true);
With this code the Culture will be German, but you can change it to any culture. Please let me know if this helps you or you need further assistance on this matter.
