715
DefaultFieldLayout can only be set to a FieldLayout contained in the FieldLayouts collection
i encounter this error on some workstations. Can you tell me if there are a know issue about this error?
In my code behind, i instantiate a simple xamdatagrid which i add a fieldlayout with this line:
XamDataGrid1.FieldLayouts.Add(myLayout)
Here is the stack trace:
  Infragistics.Windows.DataPresenter.DataPresenterBase.set_DefaultFieldLayout(FieldLayout value)
  at Infragistics.Windows.DataPresenter.DataPresenterBase.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
  at Infragistics.Windows.DataPresenter.XamDataGrid.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
  at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
  at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
  at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
  at System.Windows.DependencyObject.SetValue(DependencyPropertyKey key, Object value)
  at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
  at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
  at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
  at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange)
  at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange)
  at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
  at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
  at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
  at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs)
  at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
The datasource of the xamdatagrid is databind to an obsevableCollection.
This error appear on 3 client workstations. In my developer team, this error not appear...
Help will be appreciated.
Parents Reply Children
