Hi
The WebDataGrid Not Support Properties InitializeLayout and server side code
Hello Karthik,
Are you referring to properties and events which were available in the retired UltraWebGrid? If you are currently migrating from UltraWebGrid I would suggest referring to the WebDataGrid cheat sheet, documentation and samples:
http://www.infragistics.com/community/blogs/craig_shoemaker/archive/2011/07/11/introducing-the-webdatagrid-webhierarchicaldatagrid-cheat-sheet.aspx
http://help.infragistics.com/doc/ASPNET/2014.1/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
http://www.infragistics.com/samples/aspnet/
Please do not hesitate to contact me if you have any questions.
