Hi ,
I had a specific requirement for ultragrid in winforms to show a ultragrid column with calendar style with the option to choose only month and year. How can i restrict the dropdown to show only month and year visibility?
am trying to acheive this by using a " Infragistics.Win.UltraWinGrid.ColumnStyle.Date " .
Please suggest.
Thanks in advance,
Srinivas J
There's no way to do that. You should Submit a Feature Request to Infragistics and perhaps something like this can be added in a future release. But there is currently no built-in functionality in the control to do this.
If you have a fairly small range of dates, maybe you could use a dropdown list instead of a Date picker. You could populate the list with values like:
01/14
02/14
03/14
etc.
Another option would be to create your own control and then use a DropDownEditorButton on an editor control to drop down your custom control that allows the user to pick a month and year.
Hi Mike,
Thank you for the reply . I could able to get the look (mentioned by you ) in the date text box by masking the column style . But my problem is to restrict the look of the dropdown of the calender to show only month and year .
if it is not possible with this date control please suggest me some other control which ultragrid column supports .
Thanks & Regards,
Srinivas
