Having an issue when adding custom objects onto the Appointment.tag as ExtendedAppointmentInfo. the appointment is saving to the SQL Appointments table, but upon loading the schedule back up the Appointment is not getting serialized and I get no error. How Do I enable exceptions in the serialize of Appointment objects so I can get a clue on what to be looking for. I do have my custom objects decorated as <serializable>.,
Thanks All!
Hi Aaron,
Thank you for contacting Infragistics Developer Support.
You can configure VS to break on all exceptions. In order to do this go to Debug, click Exceptions and then you could select Thrown for an entire category of exceptions, for example, Common Language Runtime Exceptions.
Let me know if you still have issues implementing this.
I don't know what I need to enable to be able to see errors when the winschedule is databinding existing appointments. I do not know why some appointments are not being shown when the dayview is loaded up. I have enabled all Common Language Runtime exceptions and still do not see an error. The appointment does save to the dayview control during runtime, and does persist back to the SQL appointmnents table, but doesn't get loaded back up into the dayview if I exit the test app and come back in. I need to see excepctions why that appointment with the custom properties I have added into the ExtendedAppointmentInfo are not being created.
I have enabled all exceptions and I don't get an error thrown when loading up the DayView control. I need to find out why appointmnts that are saved with extendedappointmentinfo are not serialized into the appointment collection upon the project starting up. I have both classes that are being added to the Appointment.tag decorated with <Serialize>. If I add the appointment while the project is running it will be added to the correct owner and day on the DayView control and will launch the appointment dialog with the custom properties populated like I expect, but if persisted to SQL appointments table those same appointments will not load up.
Need help on this one. Thanks!
If I wipe out the AllProperties column on the appointments that have custom properties they will load and serialize into the appointents collection fine! Something is choking on the AllProperites but I don't know how to find out what its having an issue with?
Thank you for the reply.
Please make sure that in your ExtendedAppointmentInfo, you don’t have a property of another custom class that doesn’t have the Serializable tag. If that is the case mark the other custom class as serializable. If that’s not the case, please provide me with the code for your custom class. This will help me greatly in finding what is causing the issue and it will enable me to create a sample that will show how to persist the Appointment Tag for your custom class.
I am looking for your reply.
This is where the custom objects are defined in my 'WrapperClasses.vb' with the ExendedAppointmentInfo class definition.
Imports Infragistics.Win
Imports Infragistics.Win.UltraWinSchedule
#Region "ExtendedAppointmentInfo class"
<Serializable()> _
Public Class ExtendedAppointmentInfo
Private _appointment As Appointment = Nothing
Private _startTimeZoneName As String = String.Empty
Private _endTimeZoneName As String = String.Empty
Private _appointmentLabel As AppointmentLabel = Nothing
Private _appointmentStatus As AppointmentStatus = Nothing
Public Sub New()
End Sub
Public Sub New(ByVal appointment As Appointment)
Me._appointment = appointment
Public ReadOnly Property Appointment() As Appointment
Get
Return Me._appointment
End Get
End Property
Public Property Label() As AppointmentLabel
Return Me._appointmentLabel
Set(ByVal Value As AppointmentLabel)
Me._appointmentLabel = Value
End Set
Public Property Status() As AppointmentStatus
Return Me._appointmentStatus
Set(ByVal value As AppointmentStatus)
Me._appointmentStatus = value
Public Property StartTimeZoneName() As String
Return Me._startTimeZoneName
Set(ByVal Value As String)
Me._startTimeZoneName = Value
Public Property EndTimeZoneName() As String
Return Me._endTimeZoneName
Me._endTimeZoneName = Value
Public Sub InitializeFrom(ByVal source As ExtendedAppointmentInfo)
If Not source Is Nothing Then
Me.Status = source._appointmentStatus
Me.Label = source._appointmentLabel
Me._startTimeZoneName = source._startTimeZoneName
Me._endTimeZoneName = source._endTimeZoneName
If Not Me._appointment Is Nothing AndAlso Not Me.Status Is Nothing Then
Me._appointment.Appearance = Me.Status.Appearance
End If
Private _TrailerNum As String
Public Property TrailerNum() As String
Return _TrailerNum
Set(ByVal value As String)
_TrailerNum = value
End Class
#End Region
#Region "AppointmentLabel class"
''' <summary>
''' Used to store the Preloaded appointment info cboPreloaded
''' </summary>
''' <remarks></remarks>
Public Class AppointmentLabel
Private Shared ReadOnly IMAGE_SIZE As Int32 = 16
Private _displayText As String = String.Empty
Private _color As Color = System.Drawing.Color.Transparent
Private _image As Image = Nothing
Public Sub New(ByVal displayText As String, ByVal color As Color)
Me._displayText = displayText
Me._color = color
Public ReadOnly Property DisplayText() As String
Return Me._displayText
Public ReadOnly Property Color() As Color
Return Me._color
Public ReadOnly Property Image() As Image
If Me._image Is Nothing Then
Dim imageSize As Int32 = AppointmentLabel.IMAGE_SIZE
' Create a new brush and a pen
Dim brush As SolidBrush = New SolidBrush(Me.Color)
Dim pen As Pen = New Pen(SystemColors.WindowText)
' Create a new Bitmap, and fill it with the color
' specified by this instance's Color property.
Dim img As Bitmap = New Bitmap(imageSize, imageSize)
Dim gr As Graphics = Graphics.FromImage(img)
gr.FillRectangle(brush, 0, 0, imageSize, imageSize)
gr.DrawRectangle(pen, 0, 0, imageSize - 1, imageSize - 1)
' Dispose of the GDI+ resources
pen.Dispose()
brush.Dispose()
gr.Dispose()
' Assign the image to the member variable
Me._image = img
Return Me._image
Public Overrides Function ToString() As String
Return Me.DisplayText
End Function
#Region "AppointmentStatus class"
Public Class AppointmentStatus
Private _name As String = String.Empty
Private _appearance As Infragistics.Win.Appearance = New Infragistics.Win.Appearance()
Private _ID As Integer
Public Property ID() As Integer
Return _ID
Set(ByVal value As Integer)
_ID = value
Dim imageSize As Int32 = AppointmentStatus.IMAGE_SIZE
Public ReadOnly Property Name() As String
Return Me._name
Public ReadOnly Property Appearance() As Infragistics.Win.Appearance
Return Me._appearance
I will also attach a video showing how my sample works on my machine.
Below is my SaveAppointment on the frmAppointmentDialog. I am using a custom appointment dialog, overriding the BeforeDisplayAppointmentDialog event (e.cancel = true then I show the appointment dialog form passing in the Calendarinfo and the Owner.)
Do you see anything wrong here on the SaveAppointment? Thanks for your help!
Private Sub SaveAppointment()
' Subject
Me.appointment.Subject = Me.txtSubject.Text
' Location
Me.appointment.Location = Me.cboLocation.Text
' StartDateTime
Try
Dim tempStartTime As DateTime = DateTime.Parse(Me.cboStartTime.Text)
Dim tempStartDate As DateTime = Me.dtpStartTime.Value
Me.appointment.StartDateTime = New DateTime(tempStartDate.Year, tempStartDate.Month, tempStartDate.Day, tempStartTime.Hour, tempStartTime.Minute, 0)
Catch
' If we couldn't successfully parse the date, revert to the time
' of the original, untouched appointment.
Me.appointment.StartDateTime = Me.oldAppointment.StartDateTime
End Try
' EndDateTime
Dim tempEndTime As DateTime = DateTime.Parse(Me.cboEndTime.Text)
Dim tempEndDate As DateTime = Me.dtpEndTime.Value
Me.appointment.EndDateTime = New DateTime(tempEndDate.Year, tempEndDate.Month, tempEndDate.Day, tempEndTime.Hour, tempEndTime.Minute, 0)
Me.appointment.EndDateTime = Me.oldAppointment.EndDateTime
' AllDayEvent
Me.appointment.AllDayEvent = Me.chkAllDayEvent.Checked
' Reminder
If Me.chkReminder.Checked Then
Me.appointment.Reminder.DisplayIntervalUnits = DisplayIntervalUnits.Minutes
Dim reminderDisplayInterval As TimeSpan = DirectCast(Me.cboReminder.SelectedItem.DataValue, TimeSpan)
Me.appointment.Reminder.DisplayInterval = reminderDisplayInterval.TotalMinutes
Me.appointment.Reminder.Enabled = True
Else
Me.appointment.Reminder = Nothing
'Appointment Owner
appointment.Owner = Me.ApptOwner
' ExtendedAppointmentInfo
' First, see if the Appointment already has an ExtendedAppointmentInfo;
' if it does, we will continue to use it.
Dim info As ExtendedAppointmentInfo = Nothing
info = DirectCast(Me.appointment.Tag, ExtendedAppointmentInfo)
If info Is Nothing Then info = New ExtendedAppointmentInfo(Me.appointment)
''Appointment Preloaded.
'' Assign the value in the Label combo to the
'' ExtendedAppointmentInfo object's Label property
''testing commenting out this see if issue is Preloaded or not..
If Me.cboPreloaded.SelectedItem Is Nothing Then
info.Label = Nothing
info.Label = DirectCast(Me.cboPreloaded.SelectedItem.DataValue, AppointmentLabel)
If Me.cboPreloaded.SelectedIndex > 0 Then
' Assign the color for the label item to the BackColor property
' of the Appointment's Appearance.
' Me.appointment.Appearance.BackColor = info.Label.Color
Me.appointment.Appearance.ForeColor = SystemColors.WindowText
Me.appointment.Appearance.Reset()
'appointment Status
If Me.cboStatus.SelectedItem Is Nothing Then
info.Status = Nothing
info.Status = DirectCast(Me.cboStatus.SelectedItem.DataValue, AppointmentStatus)
If Me.cboStatus.SelectedIndex > 0 Then
' Assign the barcolor for the AppointmnetStatus
Me.appointment.BarColor = info.Status.Color
'TrailerNum
info.TrailerNum = txtTrailerNum.Text
'Arrive and Depart times
info.ArriveTime = cboArriveTime.Value
info.DepartTime = cboDepartTime.Value
' Store the ExtendedAppointmentInfo object in the Appointment's Tag
Me.appointment.Tag = info
' Description
Me.appointment.Description = Me.txtDescription.Text
' If the appointment does not belong to the CalendarInfo's Appointments
' collection, we must clone it and add it.
If Not Me.isExistingAppointment Then
' Add the appointment
Dim apptAsClone As ICloneable = DirectCast(Me.appointment, ICloneable)
Dim addedAppointment As Appointment = Me.calendarInfo.Appointments.Add(DirectCast(apptAsClone.Clone(), Appointment))
' Update the member variable to reflect the fact that the Appointment
' now belongs to the CalendarInfo's Appointments collection, so we know
' not to add it again in the event that it is saved more than once in a
' dialog session.
Me.isExistingAppointment = Me.calendarInfo.Appointments.Contains(addedAppointment)
' Make sure the appointment was successfully added (i.e., the
' BeforeAppointmentAdded event was not canceled).
If (Me.isExistingAppointment) Then
' Reassign the member that holds a reference to the appointment
Me.appointment = addedAppointment
Me.oldAppointment = Me.appointment
I am also using the WinScheduleMSSQLServerSupport class from the database sample. Seemed to work before I added the AppointmentStatus and AppointmentLabel custom classes into the extendedappointmnetinfo.
I have removed both custom objects from ExtendedAppointmentInfo and no luck still wont serialize the appointment upon loading. The only way the appointment will load back up from SQL table is if I do not store the Appointment.Tag = info on the SaveAppointment sub. Then and only then I am able to see the appointments load back up and get serialized back into the Dayview. I'm outta ideas here. Its got to be something simple.... Always is.. right?
Ok could it be an issue in the DataAdapterForAppointments? Is the AllProperties column defined correctly ?
Protected Overrides ReadOnly Property DataAdapterForAppointments() As SqlDataAdapter
If Me._sqlDBDataAdapterForAppointments Is Nothing Then
Me._sqlDBDataAdapterForAppointments = New SqlDataAdapter()
' Configure the SELECT command
Dim selectCommandText As String = String.Format(WinScheduleMSSQLServerSupport.SELECT_APPOINTMENTS_TEMPLATE, WinScheduleMSSQLServerSupport.APPOINTMENTS_TABLE_NAME)
Me._sqlDBDataAdapterForAppointments.SelectCommand = New SqlCommand(selectCommandText, Me.Connection)
' Configure the INSERT command
Dim insertCommand As SqlCommand = New SqlCommand()
Dim commandTextTemplate As String = "INSERT INTO {0}(AllProperties, StartDateTime, EndDateTime, Subject, AllDayEvent, OwnerKey) VALUES (@AllProperties, @StartDateTime, @EndDateTime, @Subject, @AllDayEvent, @OwnerKey) SELECT AppointmentID, AllProperties, StartDateTime, EndDateTime, Subject, AllDayEvent, OwnerKey FROM {0} WHERE (AppointmentID = @@IDENTITY)"
insertCommand.CommandText = String.Format(commandTextTemplate, WinScheduleMSSQLServerSupport.APPOINTMENTS_TABLE_NAME)
insertCommand.Connection = Me.Connection
insertCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@AllProperties", System.Data.SqlDbType.VarBinary, 1024, "AllProperties"))
insertCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@StartDateTime", System.Data.SqlDbType.DateTime, 8, "StartDateTime"))
insertCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@EndDateTime", System.Data.SqlDbType.DateTime, 8, "EndDateTime"))
insertCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Subject", System.Data.SqlDbType.VarChar, 50, "Subject"))
insertCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@AllDayEvent", System.Data.SqlDbType.Bit, 1, "AllDayEvent"))
insertCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@OwnerKey", System.Data.SqlDbType.VarChar, 50, "OwnerKey"))
Me._sqlDBDataAdapterForAppointments.InsertCommand = insertCommand
' Configure the UPDATE command
Dim updateCommand As SqlCommand = New SqlCommand()
'Changed this update from = '' to IS NULL for all the AllProperties checks. 7-17-14
commandTextTemplate = "UPDATE {0} SET AllProperties = @AllProperties, StartDateTime = @StartDateTime, EndDateTime = @EndDateTime, Subject = @Subject, AllDayEvent = @AllDayEvent, OwnerKey = @OwnerKey WHERE (AppointmentID = @Original_AppointmentID) AND (AllDayEvent = @Original_AllDayEvent) AND (AllProperties = @Original_AllProperties OR @Original_AllProperties1 IS NULL AND AllProperties IS NULL) AND (EndDateTime = @Original_EndDateTime) AND (OwnerKey = @Original_OwnerKey OR @Original_OwnerKey1 IS NULL AND OwnerKey IS NULL) AND (StartDateTime = @Original_StartDateTime) AND (Subject = @Original_Subject) SELECT AppointmentID, AllProperties, StartDateTime, EndDateTime, Subject, AllDayEvent, OwnerKey FROM {0} WHERE (AppointmentID = @Original_AppointmentID)"
updateCommand.CommandText = String.Format(commandTextTemplate, WinScheduleMSSQLServerSupport.APPOINTMENTS_TABLE_NAME)
updateCommand.Connection = Me.Connection
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@AllProperties", System.Data.SqlDbType.VarBinary, 1024, "AllProperties"))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@StartDateTime", System.Data.SqlDbType.DateTime, 8, "StartDateTime"))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@EndDateTime", System.Data.SqlDbType.DateTime, 8, "EndDateTime"))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Subject", System.Data.SqlDbType.VarChar, 50, "Subject"))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@AllDayEvent", System.Data.SqlDbType.Bit, 1, "AllDayEvent"))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@OwnerKey", System.Data.SqlDbType.VarChar, 50, "OwnerKey"))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AppointmentID", System.Data.SqlDbType.Int, 4, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AppointmentID", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AllDayEvent", System.Data.SqlDbType.Bit, 1, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AllDayEvent", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AllProperties", System.Data.SqlDbType.VarBinary, 1024, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AllProperties", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AllProperties1", System.Data.SqlDbType.VarBinary, 1024, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AllProperties", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_EndDateTime", System.Data.SqlDbType.DateTime, 8, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "EndDateTime", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_OwnerKey", System.Data.SqlDbType.VarChar, 50, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "OwnerKey", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_OwnerKey1", System.Data.SqlDbType.VarChar, 50, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "OwnerKey", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_StartDateTime", System.Data.SqlDbType.DateTime, 8, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "StartDateTime", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_Subject", System.Data.SqlDbType.VarChar, 50, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "Subject", System.Data.DataRowVersion.Original, Nothing))
updateCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Select_AppointmentID", System.Data.SqlDbType.Int, 4, "AppointmentID"))
Me._sqlDBDataAdapterForAppointments.UpdateCommand = updateCommand
' Configure the DELETE command
Dim deleteCommand As SqlCommand = New SqlCommand()
'CHnaged Delete command from = '' to IS NULL 7-17-14
commandTextTemplate = "DELETE FROM {0} WHERE (AppointmentID = @Original_AppointmentID) AND (AllDayEvent = @Original_AllDayEvent) AND (AllProperties = @Original_AllProperties OR @Original_AllProperties1 IS NULL AND AllProperties IS NULL) AND (EndDateTime = @Original_EndDateTime) AND (OwnerKey = @Original_OwnerKey OR @Original_OwnerKey1 IS NULL AND OwnerKey IS NULL) AND (StartDateTime = @Original_StartDateTime) AND (Subject = @Original_Subject)"
deleteCommand.CommandText = String.Format(commandTextTemplate, WinScheduleMSSQLServerSupport.APPOINTMENTS_TABLE_NAME)
deleteCommand.Connection = Me.Connection
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AppointmentID", System.Data.SqlDbType.Int, 4, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AppointmentID", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AllDayEvent", System.Data.SqlDbType.Bit, 1, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AllDayEvent", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AllProperties", System.Data.SqlDbType.VarBinary, 1024, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AllProperties", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_AllProperties1", System.Data.SqlDbType.VarBinary, 1024, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "AllProperties", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_EndDateTime", System.Data.SqlDbType.DateTime, 8, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "EndDateTime", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_OwnerKey", System.Data.SqlDbType.VarChar, 50, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "OwnerKey", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_OwnerKey1", System.Data.SqlDbType.VarChar, 50, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "OwnerKey", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_StartDateTime", System.Data.SqlDbType.DateTime, 8, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "StartDateTime", System.Data.DataRowVersion.Original, Nothing))
deleteCommand.Parameters.Add(New System.Data.SqlClient.SqlParameter("@Original_Subject", System.Data.SqlDbType.VarChar, 50, System.Data.ParameterDirection.Input, False, CType(0, Byte), CType(0, Byte), "Subject", System.Data.DataRowVersion.Original, Nothing))
Me._sqlDBDataAdapterForAppointments.DeleteCommand = deleteCommand
Return Me._sqlDBDataAdapterForAppointments
Thank you for the provided code snipped.
What could be the reason for the issue is that the size of the AllProperties field might be too small. I tried using a varbinary(1024) field with ExtendedAppointmentInfo object as the tag and I wasn’t able to save the appointment. After removing the AppointmentStatus and AppointmentLabel properties I was able to save the appointment to the varbinary(1024) field. Then I tested the sample with varbinary(8000), which I was using previously, and everything worked fine.
So please try using a varbinary with bigger size (for example 8000) and try to save the appointment again.
Let me know if this suggestion fixes your issue.
