455
System.ArgumentException "specified 'parentCollection' does not match the specified task's parent collection
I am getting an exception when I am using passing an indented task into the TaskDialog and I'm not sure why.  In the code below, I am handling the TaskDialogDisplaying event, and inferring whether the task is an exposition, a phase, or a task based on how far it's indented.  If it's not indented, it opens the TaskDialog correctly.  If it is indented at all, I get the exception.  Why are ultraGanttView.ActiveTasks & ultraGanttView.Tasks different for unindented and indented tasks?
Myca
namespace GanttChart.ViewModel
    public partial class BindingGanttView : Form
        #region Constructor
        public BindingGanttView()
            InitializeComponent();
        #endregion
        #region Private Methods
        #endregion
        #region Form Load Event
        private void BindingGanttView_Load(object sender, EventArgs e)
            //  Set the BindingContextControl property to reference this form
            this.ultraCalendarInfo1.DataBindingsForTasks.BindingContextControl = this;
            this.ultraCalendarInfo1.DataBindingsForProjects.BindingContextControl = this;
            // Set the DataSource and DataMember for Project and Tasks using the SetDataBinding method
            this.ultraCalendarInfo1.DataBindingsForProjects.SetDataBinding(ExpositionRepository.Instance, "ShowPlans");
            this.ultraCalendarInfo1.DataBindingsForTasks.SetDataBinding(ExpositionRepository.Instance, "Tasks");
            //  Set the DataBinding members for Projects
            this.ultraCalendarInfo1.DataBindingsForProjects.IdMember = "PlanGuid";
            this.ultraCalendarInfo1.DataBindingsForProjects.KeyMember = "PlanID";
            this.ultraCalendarInfo1.DataBindingsForProjects.NameMember = "PlanName";
            this.ultraCalendarInfo1.DataBindingsForProjects.StartDateMember = "PlanStartTime";
            //  Set the DataBinding members for Tasks
            // Basic Task properties
            this.ultraCalendarInfo1.DataBindingsForTasks.NameMember = "TaskName";
            this.ultraCalendarInfo1.DataBindingsForTasks.DurationMember = "TaskDuration";
            this.ultraCalendarInfo1.DataBindingsForTasks.StartDateTimeMember = "TaskStartTime";
            this.ultraCalendarInfo1.DataBindingsForTasks.IdMember = "TaskGuid";
            this.ultraCalendarInfo1.DataBindingsForTasks.ProjectKeyMember = "PlanID";
            this.ultraCalendarInfo1.DataBindingsForTasks.ParentTaskIdMember = "ParentTaskGuid";
            this.ultraCalendarInfo1.DataBindingsForTasks.PercentCompleteMember = "TaskPercentComplete";
            // All other properties
            this.ultraCalendarInfo1.DataBindingsForTasks.AllPropertiesMember = "AllProperties";
            //  Since we are showing a task that belongs to an explicitly defined
            //  project (i.e., not the UnassignedProject), assign that project to
            //  the control's Project property so the control knows to display that project.
            this.ultraGanttView1.CalendarInfo = new UltraCalendarInfo();
            this.ultraGanttView1.Project = this.ultraGanttView1.CalendarInfo.Projects.Add("MAMdb", DateTime.Now);
            this.ultraGanttView1.GridAreaWidth = 400;
        #endregion
        #region //Event Handlers
        public void ultraGanttView1_TaskDialogDisplaying(object sender, Infragistics.Win.UltraWinGanttView.TaskDialogDisplayingEventArgs e)
            if (e.Task != null)
                // The following infers whether a task is a Exposition, a phase, or a basic task based on whether it is indented under it's parent task
                if (e.Task.Parent == null) // entry is a Exposition because it has no parent task and is not indented
                    openDialogExpositionEntry();
                else if (e.Task.Parent.Parent == null) //entry is a phase because it has just one parent and no grandparents (1 indent)
                    openDialogPhaseEntry();
                else //entry is a task because it has parents and grandparents (2 indents)
                    openDialogTaskEntry();
        #endregion //Event Handlers
        #region  //Data entry forms
        private void openDialogExpositionEntry()
            // There is no additional data to define Expositions, so the default Infragistics form is sufficient
            TaskDialog infragisticsDialog = new TaskDialog(ultraGanttView1.ActiveTask, ultraGanttView1.CalendarInfo.Tasks, ultraGanttView1);
            infragisticsDialog.Name = "Exposition Entry";
        private void openDialogPhaseEntry()
            UltraComboEditor phaseType = new UltraComboEditor();
            //(infragisticsDialog.Controls[0] as UltraTabControl).Tabs.["General"].TabPage.Controls.Add(phaseType);
            infragisticsDialog.Controls.Add(phaseType);
        private void openDialogTaskEntry()
        #endregion //Data entry forms
Parents
No Data
Reply
  • 23930
    Hello Myca,
    I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Children
