55
XamDataGrid, Collapsing a column based on a visibility value
I have already seen a few examples about this issue. But i am not able to correlate to my problem. Please help me in doing it.
My problem is that i have a datagrid with two fields and i want to collapse one field based on a visibility value change in the code.
The XAML code part where i define the fields is as follows :
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout>
<igDP:FieldLayout.Fields>
<igDP:Field Visibility="{Binding Source={StaticResource ViewModel}, Path=bRValidation_Display}" Name="BO" Label="BLine Operation" />
<igDP:Field Name="ROperation" Label="ROperation"/>
igDP:FieldLayout>
and the resources is defined in the start as
<Grid.Resources>
<rvm:OViewerViewModel x:Key="ViewModel"/>
</Grid.Resources>
and rvm namespace is defined in the starting !!
the C# code where i define the visibility variable is
public Visibility bRValidation_Display
get { return
bVisibility; }
set
bVisibility =value;
NotifyPropertyChanged("bRValidation_Display");
This visibility value is set in the later part of the code . I tried to check the values using breakpoints and found that the visibility value of the BrValidation_Display when checked in the XAML code in the fields line during execution can be seen as collapsed . but the output window still shows the field in the grid without collapsing it . Is the value not binded properly or the problem is related to the visual tree. Where am i going wrong. Please provide me a way to correct this as well.
Parents Reply Children
