Hi.
i tried to use both Maked input and date input, no successi do binding to Timespan, at the moment i can display this value as: hh:mm:ss and in edit mode the same.
all i want to do is to show in view mode and also in edit mode like this: hh:mm (without the second)
and ofcourse to limit the user so he can input only the range if time (24), means from: 00:00 to 23:59
thanks for the help
Thank you for your post. I have been looking into it and I can suggest you use the XamMaskedInput and set its Mask Property to “{}hh:mm” in order to achieve the functionality you want. Please let me know if you need further clarifications on this matter.
Will it fit the 24 time and not the 12 with AM PM?
i mean will it not convert 20:00 to 8:00 or backwards..
Hello Assaf,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
