85
XamComboEditor in xamDataGrid not calling setter in underlying property when adding new row
I'm trying to incorporate a xamDataGrid into an MVVM application.
I have the grid bound to an observable collection in my viewModel.  This collection is of another viewModel object type.
Inside my grid, some of the editors are set to xamComboEditors which items are bound to another collections in my viewmodel.
I'm having trouble when using the AllowAddNew feature.  If the user initializes the new row from a field with a combo editor in it, the new item is added to my collection, however the property setter from the combo select is lost.  If the user initializes the new row from a text or even a check box editor, the new row is added to my collection and then the property setter is called.  I was trying to change the DataItemUpdateTrigger value, but have not had any luck.  I think I am missing something.
Here is the a simplified example of the code I am using:
Grid:
<igWPF:XamDataGrid Visibility="{Binding TimeEntryCalls, Converter={StaticResource NullVisibilityConverter}}"IsSynchronizedWithCurrentItem="True" DataSource="{Binding Path=TimeEntryCalls, Mode=TwoWay}" MaxHeight="200"  >
 <igWPF:XamDataGrid.FieldLayoutSettings>
  <igWPF:FieldLayoutSettings AutoGenerateFields="False" AddNewRecordLocation="OnBottom" AllowAddNew="True" AllowDelete="True" />
  </igWPF:XamDataGrid.FieldLayoutSettings>
  <igWPF:FieldLayout.Fields>
   <igWPF:UnboundField Name="Equip" Label="Vehicle" BindingPath="SelectedTimeCall.Equip" BindingMode="TwoWay" >
    <igWPF:Field.Settings>
     <igWPF:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}" DataItemUpdateTrigger="OnCellValueChange"  >
      <igWPF:FieldSettings.EditorStyle>
       <Style TargetType="{x:Type igEditors:XamComboEditor}">
        <Setter Property="ItemsSource" Value="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType={x:Type UserControl}}, Path=DataContext.EquipmentForDivision, IsAsync=True}" />
        <Setter Property="SelectedItem" Value="{Binding DataItem.SelectedTimeCall.Equip, Mode=TwoWay}"/>
        <Setter Property="DisplayMemberPath" Value="EquipCode" />
        <Setter Property="AcceptsArrowKeysInEditMode" Value="True"/>
        </Style>
      </igWPF:FieldSettings.EditorStyle>
     </igWPF:FieldSettings>
    </igWPF:Field.Settings>
   </igWPF:UnboundField>
   <igWPF:UnboundField Name="IsDriver" Label="Driver" BindingPath="SelectedTimeCall.IsDriver" BindingMode="TwoWay" Converter="{StaticResource IgnoreNewItemPlaceHolderConverter}" >
     <igWPF:FieldSettings EditorType="{x:Type igEditors:XamCheckEditor}" DataItemUpdateTrigger="OnCellValueChange">
   <igWPF:UnboundField Name="CallHours" Label="Hours"  BindingPath="SelectedTimeCall.CallHours" BindingMode="TwoWay">
     <igWPF:FieldSettings DataItemUpdateTrigger="OnLeaveCell" EditAsType="Core:Double"/>
  </igWPF:FieldLayout.Fields>
  </igWPF:FieldLayout>
 </igWPF:XamDataGrid.FieldLayouts>
</igWPF:XamDataGrid>
Code from my viewModel:
private ObservableCollection<CallViewModel> timeEntryCalls;
public ObservableCollection<CallViewModel> TimeEntryCalls
 get
  return timeEntryCalls;
 set
  timeEntryCalls = value;
   OnPropertyChanged();
public List<EQUIPMENT> EquipmentForDivision { get; set; }
void timeEntryCalls_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
 if (e.Action == NotifyCollectionChangedAction.Add)
  try
   foreach (CallViewModel call in e.NewItems)
     //calling methods inside CallViewModel to initialize values
  catch (Exception ex)
   //handle any exceptions
 OnPropertyChanged("TimeEntryCalls");
Parents
  • 138253
    Verified Answer
    Hello Laura,
    Thank you for your post. I have been looking into it and I created a sample project for you following your scenario and everything seems to work ok on my side. I only set the DataType of the UnboundField to the object type that it will use. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
    XamDataGridComboEditor.zip
Reply Children
