Just like excel does for column chart, is it possible showing value above or under column? I create a marker template, it works at first but if I switch between tabs, the marker moves place. demo is attached, can somebody please help to check it out?
Hello Jun,
Thank you for your post.
I have been looking through it and the code you have provided and it seems that the reason for the behavior that you are getting is because you setting the Margin property of the Grid of the DataTemplate for the Marker. I would suggest you set Margin property of that Grid, you can change your converter, so as to check whether the value is negative and returns true or false. You can use DataTrigger and set the Margin property for negative values depending on the value of the converter. I modify you attached project, to show you how can implement this approach.
Please let me know of you need any further assistance on this matter
it works in this demo but still doesn't make sense in my product application, it must be local style/theme problem,
anyway, thanks you very much.
Thank you for your feedback.
If you could send me an application that is showing the behavior in your scenario, I would be able to research what might be causing the issue and how it can be avoided.
