on a column with xamcomboeditor, the sort and filter occur on the valuepath instead of displaymemberpath. am i missing a flag? i need it to sort and filter with the values the user sees.
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through your post and I suggest set the DisplayMemberPath and ValuePath to the same Properties in order to achieve your scenario, because the sorting and filtering in XamDataGrid is made by the Value property of the Editor of the Field.
Feel free to write me if you have any other questions.
Although that would allow it to sort and filter, it would require that we change the bound objects to hold display data instead of identification data.
I have coded custom sort and filter routines to satisfy my needs. However, I think sort and filter should happen on the display field in a future release.
After some research, this issue has been determined to be a new feature request. I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR13510.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
what is the current status of the feature request FR13510?I wrote a mail to the dsmanager as you suggested, but did not get any information from this service.
Thank you.
Currently this is feature is not implemented and if you want to speed the process you can log a Product idea, too. You can do this here:
http://ideas.infragistics.com/
Also you can see these forum threads:
http://www.infragistics.com/community/forums/p/45162/259559.aspx
http://www.infragistics.com/community/forums/t/67980.aspx
http://www.infragistics.com/community/forums/t/71650.aspx
where it is discussed how to sort and filter based on the DisplayMemebrPath.
