Hi there,
I'm currently having an issue with a XamComboEditor that sometimes returns an unhandled exception.
This happens when the AutoComplete is used to get the data from the dropdown
It happens with no apparent reason and only occasionally.
This is the error that is happening (Silverlight application):
This is the Combo definition:
<ig:XamComboEditor x:Name="igOtherServiceTypes" Grid.Row="1" Grid.Column="1" Margin="10,10,10,10" Height="25" ItemsSource="{Binding OtherServiceTypes, Mode=TwoWay}" SelectedItem="{Binding Path=SelectedOtherServiceType, Mode=TwoWay}" IsEditable="True" AutoComplete="True" AutoCompleteDelay="500" AllowFiltering="True" DisplayMemberPath="OtherServicesTypeDescription" OpenDropDownOnTyping="True" TabIndex="0" cal:Message.Attach="Loaded = OtherServiceTypes_Loaded($source, $eventArgs)"> <i:Interaction.Behaviors> <sfb:ComboBoxSelectText/> </i:Interaction.Behaviors></ig:XamComboEditor>
Do you have any idea why this happens?
Thank you.
Hello Helder,
Thank you for your post. I have been looking into it and I can say that we no longer provide fixes for SL4, so I can suggest you test your application with some of our latest versions 13.2 or 14.1, which supports SL5 only, and see if the issue still occurs.
