The page I need to fix has UltraWebGrid control on it.
UltraWebGrid
When there are more rows then control can display, scroll bars appear. When clicking on a row, the data details page is displayed. However, after trying to scroll, when clicking on a row, nothing happens. Than when clicking on a columns to sort, clicking begins working again. I cannot find solution for this one. Need help.
Thank you
Hello Eugene Gruzin,
Thank you for posting in our forums!
The first question I have is: could you please let me know what browser and version you are experiencing this behavior on?
Thank you for your reply, Michael.
We are using IE9 and infragistics version we have is 5.2
Hi Eugene Gruzin,
Thank you for the information. IE9 is not supported in Infragistics 5.2. According to our Supported Environments page, you will need to upgrade to Infragistics 10.2 through 11.1 for IE9 support. You can find more information in our Supported Environments page here:
http://www.infragistics.com/help/supported-environments
I recommend upgrading to Infragistics 11.1 because starting with 11.2, we no longer provide the UltraWebGrid. If you upgrade to a version newer than that, which would also provide IE9 support, you would need to migrate to the WebDataGrid or WebHierarchicalDataGrid. For more information on this change, please see the following blog:
http://www.infragistics.com/community/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx
If you have any further questions or concerns with this, please let me know.
And after reading some comments on the web, I saw, that it IE9 and infragistics version may not be compatible with each other.
I browsed a little bit, and found that I can insert <meta http-equiv="X-UA-Compatible" content="IE=9"/> inside of the page's head tag.
It seems to be working now.
