I am inserting pictures into cells in my ultragrid instance. I am trying to have it display the cells in a way that there is no spacing in between them, not even 1 pixel. I've tried all of the below but still a little 2pixel white line exists. Any idea how I might remove that line?
Thank You,
Tim
Private Sub ugMain_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeRowEventArgs) Handles ugMain.InitializeRow
e.Row.RowSpacingAfter = 0
e.Row.RowSpacingBefore = 0
End Sub
Private Sub UltraGrid1_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles ugMain.InitializeLayout
'show numbers for the rows
e.Layout.Override.RowSelectors = Infragistics.Win.DefaultableBoolean.True
e.Layout.Override.RowSelectorNumberStyle = Infragistics.Win.UltraWinGrid.RowSelectorNumberStyle.VisibleIndex
e.Layout.Override.RowSelectorHeaderStyle = Infragistics.Win.UltraWinGrid.RowSelectorHeaderStyle.SeparateElement
e.Layout.Override.RowSelectorHeaderAppearance.TextHAlign = Infragistics.Win.HAlign.Center
'set size
e.Layout.Override.MinRowHeight = e.Layout.Override.DefaultColWidth
e.Layout.Override.DefaultRowHeight = 30
e.Layout.Override.DefaultColWidth = 30
'selection
e.Layout.Override.SelectTypeCol = Infragistics.Win.UltraWinGrid.SelectType.None
e.Layout.Override.SelectTypeRow = Infragistics.Win.UltraWinGrid.SelectType.None
e.Layout.Override.HeaderClickAction = Infragistics.Win.UltraWinGrid.HeaderClickAction.Select
e.Layout.Override.SelectTypeCell = Infragistics.Win.UltraWinGrid.SelectType.SingleAutoDrag
e.Layout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.CellSelect
'disable sizing
e.Layout.Override.AllowColSizing = Infragistics.Win.UltraWinGrid.AllowColSizing.None
e.Layout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.Fixed
'center the cell images
e.Layout.Override.CellAppearance.ImageHAlign = Infragistics.Win.HAlign.Center
e.Layout.Override.CellAppearance.ImageVAlign = Infragistics.Win.VAlign.Middle
e.Layout.Override.CellAppearance.BorderAlpha = Infragistics.Win.Alpha.Transparent
e.Layout.Override.BorderStyleCell = Infragistics.Win.UIElementBorderStyle.None
e.Layout.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.None
e.Layout.Override.ButtonStyle = Infragistics.Win.UIElementButtonStyle.Borderless
e.Layout.Override.RowAppearance.BorderAlpha = Infragistics.Win.Alpha.Transparent
e.Layout.Override.RowAppearance.BackColor = Color.White
e.Layout.Override.CellPadding = -5
e.Layout.Override.CellSpacing = -5
Set CellSpacing and CellPadding to 0 and not -5. Negative numbers are not valid.
Thanks for the reply.
I set all the negative values to 0 but no change in the spacing.
What you could do in your case is to set BorderStyle of Cells and Rows to none in InitializeLayoutEvent you could use code like:
e.Layout.Override.CellSpacing = 0;
e.Layout.Override.CellPadding = 0;
e.Layout.Override.BorderStyleCell = Infragistics.Win.UIElementBorderStyle.None;
e.Layout.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.None;
e.Layout.Override.BorderStyleHeader = Infragistics.Win.UIElementBorderStyle.None;
And also instead to set CellValue to be Image, add cell appearance
cell.Appearance.ImageBackground = img;
cell.Appearance.ImageBackgroundStyle = Infragistics.Win.ImageBackgroundStyle.Stretched;
cell.Appearance.ImageBackgroundStretchMargins = new Infragistics.Win.ImageBackgroundStretchMargins(0, 0, 0, 0);
On this way you will get as minimum as possible spacing between cells.
I hope that this will helps you.
Thank You! That worked well.
