Hi,I am using igDataChart inside a igDialog window that opens external page, so essentially the chart is inside an iframe window.My problem is with the tooltip position when hovering on the columns that are close to the right edge of the dialog.The tooltip always opens to the right so the tooltip for the right columns is being cut and is unreadable to the user.
attached are two printscreens of the chart that shows the problem.printScreen1.png - is the tooltip as it should beprintScreen2.png - is the tooltip being cut
Is there anyway to control the tooltip position - this is item tooltip for the chart
Thanks for your help
Hello Amos_silberman,
I followed the steps you suggested and was unable to reproduce the behavior you're describing. I created an igDataChart within an igDialog, however, the tooltip continued to display outside of the bounds of the dialog window. You can see this behavior in the screenshot which I have attached to this message.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
If the project does not work correctly, this indicates either a problem possibly specific to your environment, or a difference in the DLL versions we are using. My test was performed using the latest version of IgniteUI 2014.1.
If the project does show the product feature working correctly, this indicates a possible problem in the code of your application. It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
Please let me know if I can provide any further assistance.
Thanks for your quick response, and for your time.You have missed one step of the process I suggested, that the dialog should open an external page - another html page, and with igDialog it is done through iframe. I am nor near my computer right now, so I will be able to modify you example tomorrow.If you will try to open another html page with the chart in the opened page, you will get the tooltip behaviour I was talking about.
Thanks again
