Hi, I originally had my UltraWebGrid using the built in Checkbox columntype but since the latest version of Google Chrome, it's not picking up the 'true' value when a checkbox is checked on the server. However it works fine when running from Visual Studio locally. If someone knows why this would be please let me know. In the meantime I am trying to put an asp.net checkbox control into this cell as a replacement. This is my code below. I create the asp.net checkbox dynamically in the Page_Init event and set the EditorControlID below in the Page_Load. It's not showing up in the grid cell. Can someone explain what i'm doing wrong? I see the checkbox outside of the grid at the bottom of the page instead. I've checked some other posts and it seems I'm doing it right. FYI, this is a Hierarchical grid that is created at runtime. I'm using 2007 Volume 1 Infragistics controls.
Dim xCol As New UltraGridColumn xCol.Type = ColumnType.Custom xCol.EditorControlID = xChk.ID 'Dynamically created asp.net checkbox control ID xCol.Header.Caption = "Test"
uwgRecItems.DisplayLayout.Bands(1).Columns.Insert(0, xCol)
uwgRecItems.DisplayLayout.Bands(1).Columns(0).AllowUpdate = AllowUpdate.Yes
I've had the same issue reported on a live site. I updated them from Volume 7.1 to 11.1 (.NET2) - but have still go the issue. I have another site running the same code which is working (on 11.1) SP.
