Hi there,
I have the latest version of the WinForms controls (14.1.20141.2059), and I noticed some odd behavior. When setting the DropDownStyle to DropDownList in code after the form load event, the combo box seems to get the highlighed back color that makes it look like it should be read only. However, the cursor is still present and I can free type in the box. Selecting an item from the list also exhibits the same behavior (and throws format exceptions in the log).
Has anyone else seen this? Has this already been reported?
P.S. - Setting the DropDownStyle in the designer or during the load event seems to work just fine.
Hi Dave,
Thank you for contacting Infragistics Developer Support.
I have logged this issue in our internal tracking system with ID 177059 and also created a case for this - CAS-141468-L8H3P9. You can view your active support cases from the following link:
https://www.infragistics.com/my-account/support-activity
