we are facing the "Parameter is not valid."
at System.Drawing.Graphics.GetHdc()
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureTextGDIOrThemed(String text, Font font, TextFormatFlags textFormatFlags)
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureCharacterRangesGDI(String text, Font font, TextFormatFlags textFormatFlags, CharacterRange[] ranges)
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.ReMeasureParts(String text, Int32[] parts, Single[] widths, Int32 partStartIndex, Int32 partEndIndex, Font font, Single& lineHeight)
at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureParts(String text, Int32[] parts, Font font, Single& lineHeight)
at Infragistics.Win.FormattedLinkLabel.NodeText.TextLayoutInfo.Measure(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeText.PositionSelf(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionHelper(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.Position(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionChildNodes(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBlock.PositionChildNodes(PositionElementsInfo& info)
at Infragistics.Win.FormattedLinkLabel.NodeBase.CalcSize(IFormattedLinkLabelOwner owner, Graphics graphics, Int32 maxWidth)
at Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.CalcSize(Graphics graphics, Font baseFont, AppearanceData& defaultAppearance, Int32 widthConstraint, DefaultableBoolean wrapText, GdiDrawStringFlags gdiDrawStringFlags)
at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.CalculateCaptionAreaHeight()
at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.CalculateGlassRect()
at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.ExtendGlassIntoRibbon(IntPtr handle)
at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.RefreshGlass()
at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.Dirty(RibbonMetricsFlags flags)
at Infragistics.Win.UltraWinToolbars.Ribbon.OnFormCaptionChanged()
at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnFormTextChanged(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnTextChanged(EventArgs e)
at System.Windows.Forms.Form.OnTextChanged(EventArgs e)
at System.Windows.Forms.Control.set_Text(String value)
at System.Windows.Forms.Form.set_Text(String value)
Hi Wagas,
Thank you for contacting Infragistics Developer Support.
What version of Infragistics for Windows Forms are you using? When is the issue happening? Can you give us steps to reproduce the issue? Does it happen randomly or you can reproduce it every time? Can you provide me with a sample that reproduces this issue?
I am looking forward to your reply.
I am using 11.2 version. This issue is happening every time. am sorry i cannot post code here due to company privacy rule. but i can explain situation in which this exception occur and big red cross appears instead of tool bar.
I am loading a huge dataset in ultragrid (Image column included in every row). while this grid is being loaded i start changing tabs (on tab change i am just setting text on toolbar nothing else). This exception occurs and big red cross appears instead of toolbar.
I am still following this thread. Have you been able to isolate this in a separate sample? Let me know if you menage to create one, I will be glad to further investigate it.
We have isolated this to happen for our users in at least one specific case.
When the user has the Infragistics ribbon, hits the ALT-key to activate the KeyTips and then closes the application by clicking the X in the upper right corner of the form. This will crash the ribbon every time for our application.
If the KeyTips are not active the application will close normally.
Thank you for the update.
I created a small sample in order to test your scenario and I still can’t reproduce this issue. I am attaching the sample along with a video, which shows the behavior of the sample on my machine.
What version do you use? I tested it with the latest release of 14.2 and everything seems to work for me. Do you reproduce the exception with the attached sample? If you can’t, please modify the sample, so that the issue can be reproduced with it.
Thank you for your collaboration.
I am looking forward to hearing from you.
Thanks for the reply. We are using Infragistics v14.2.20142.2010.
We found a solution for our crashes. If we change the ribbon IsGlassSupported to false all our crashes go away. Or if we have the PC with non-aero themes it goes away (not really a solution since we can't impose that on customer machines).
A typical call stack for this crash where you can see the Glass calls in the crash is:
Exception Count: 3
Exception Source: System.Drawing
Exception Type: System.ArgumentException
Exception Message: Parameter is not valid.
Exception Target Site: GetHdc
---- Stack Trace ----
System.Drawing.dll : N 1623891
Infragistics4.Win.v13.1.DLL : N 00249
Infragistics4.Win.v13.1.DLL : N 00198
Infragistics4.Win.v13.1.DLL : N 00683
Infragistics.Win.FormattedLinkLabel.TextLayoutInfo.Measure(PositionElementsInfo& info)
Infragistics4.Win.v13.1.DLL : N 00127
Infragistics4.Win.v13.1.DLL : N 00735
Infragistics4.Win.v13.1.DLL : N 00073
Infragistics4.Win.v13.1.DLL : N 00032
Infragistics4.Win.v13.1.DLL : N 01110
Infragistics4.Win.v13.1.DLL : N 00252
Infragistics4.Win.v13.1.DLL : N 00794
Infragistics.Win.UltraWinToolbars.RibbonMetrics.CalculateCaptionAreaHeight()
Infragistics4.Win.UltraWinToolbars.v13.1.DLL : N 00971
Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.ExtendGlassIntoCaption(IntPtr handle)
Infragistics4.Win.UltraWinToolbars.v13.1.DLL : N 00139
Infragistics4.Win.UltraWinToolbars.v13.1.DLL : N 00375
mscorlib.dll : N 00000
We have only one file that can reproduce this issue, but we will release the IsGlassSupported change to our users and see if our crash logs show a reduction in big red X exceptions in the next few weeks. Our customers can live without glass support if they no longer crash. If this doesn't fix our problems I will post here again and try running your sample program.
I just had a chance to run your sample program and had the same results you did. No crashes at all.
I did notice that you did not change the caption of the form while closing (something we do) and modified your code and still did not have any exceptions. Everything worked perfectly.
Your attached video was identical to what my app running looked like.
Thanks for taking the time to make up this program so that I could try it. I was hoping to get the crash, but like you we rarely see the crash our customers get. So far we have one file that we can reproduce the issue with after six years of trying. Our customers get 5-6 crashes reported each day (out of thousands of customers).
We put the change to remove the IsGlassSupported for the ribbon and have no reported crashes in over a week of customer use. Normally we get 5-6 crashes a day so dropping to 0 per day seems significant. These numbers are reported from customers using our latest patch with this change.
Customers using the slightly older code without this change are still reporting Infragistics ribbon crashes.
