I have a problem with changing XamOutlookCalendarView.CurrentViewMode from OutlookCalendarViewMode.DayViewWeek to OutlookCalendarViewMode.DayViewDay.
Changing to and from another ViewModes works perfectly, but in the case above simply nothing happens. I need to select previously selected day when i change from DayViewWeek to DayViewDay.
Help please!
While i'm at it, there is another thing with changing XamOutlookCalendarView.CurrentViewMode that bugs me. First time that change from DayViewWeek to MonthView is happening (or other way around) it takes noticeable amount of time.
Is there a way to fix it?
Hello Maxim,
I have logged this with development under ID: 177121 and I have also created a support ticket on your behalf: CAS-141555-S7X2F7 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://www.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://www.infragistics.com/Membership/MySupport.aspx
