I cannot get my toolbar of full of StateButtons to display 2 columns at run time. I've attached a screenshot of what I'm attempting to emulate. Any suggestions of how I can accomplish always showing 2 columns buttons on my toolbar?
Thank You for your help,
Version: 7.1.20071.40
I am just checking about the progress of this issue. Let me know if you need my further assistance on this issue.
Hi Milko,
Thanks for the added information and I did submit a product upgrade request like you suggested. I cannot open the project you sent because of an incompatibility. Would you have a Visual Studio 2010 version of this project? Also, if there is a VB.NET version too that would be really nice. If not I'll convert it.
Tim
Hello Tim,
Thank you for submitting a new product idea.
Please find attached Visual Studio 2010 with VB.NET version of my example solution. Please check my sample and let me know if this is the final result you need for your application.
This looks like just what I need.
Thanks Milko!
Hi Again Milko,
How do you add a table layout panel to an UltraToolbar? I see that you did it but cannot figure out how you did it.
Thank You,
Here is how you can add table layout panel to UltraToolbar:
Add table layout panel to your form and arrange it with buttons you need. Set the visible property of the table layout panel in properties window to false.
In UltraToolbarsManager select the Toolbar you need to add the table layout panel and add click insert new tool button.
In New Tool window select Control Container tool type set Caption, Key, Customizer Caption and Category to some appropriate value for you and click Add button.
Select the Control Container you just added. In properties window set Control property to table layout panel you add in step one.
Please let me know if you need my further assistance on this issue.
Thank you for the instructions. Would you know if this works in an MDI app in Visual Studio 2005 using Infragistics v7.1 ?
I keep adding the table layout to my mdi parent form, then adding to the toolbar and it disappears. I can select it still from the control selector in the Properties panel but it is no where to be found in the designer nor at runtime.
I have set Form1 IsMdiContainer property to true. Then I have added a new form to the project – Form2 and have set it’s MdiParent to Form1. When I have run the application it works fine.
Please note I have used VS2010 CLR4.0 and Infragistics Windows Forms 14.1 in my solution. If this doesn’t work with Infragistics 7.1 the you should upgrade your application to a newer version of the components. Please follow the next link to check which versions of Infragistics Windows Forms are currently supported http://www.infragistics.com/help/product-lifecycle
Please check attached solution and let me know if you have any further questions.
Hi Tim,
Please let me know if you need my further assistance on this matter.
I can't figure out how you created the separator between the groups in the example you sent me... which was a great example btw and I am accomplishing a lot with it.
