I need to develop semi gauge(half circle without values). Could you please help on this.
Madhu.
Hello Madhu,
Thank you for your post!
I have been looking into it and it seems that I am missing something from your scenario. Would you please further explain the functionality you want to achieve?
Also for some reason the picture that you are have added in your second post does not pass through. Would you please re-send your attachments using Internet Explorer or Mozilla Firefox and send them as zip file in order to ensure that the files will be received successfully?
Thank you for the cooperation. Looking forward to hearing from you.
Hi , Thank you for your support.
I need to develop semi circle gauge, I need to rotate the needle based on the values from service . the values not visible on semi circle gauge. I can set the range values. but the colors range from green to red. how can I give values..? (like XamTreeMapCOntrol)
I am attaching the screenshot. Please find the screen shot in the below path.
https://drive.google.com/file/d/0B867YMLkegUJb3ViZGtZNTd1T2c/edit?usp=sharing
if any additional information required please let me know. I am looking forward your support
Thanks in advance.
Madhu
Thank you for the provided information. I have been looking into the screenshot you have provided and have created a small sample application for you.
In the sample application I have a simple XamRadialGauge. The range of the entire gauge is set from 0 to 10. Then it has 3 minor ranges, that are colored green, yellow and red.
In order to set the shape to your desired one you can set the BackingShape property of the XamRadialGauge. I have set the LabelExtent property to 0 in order to hide the Labels. To hide the tick marks I have set the following brushes to transparent - TickBrush and the MinorTickBrush.
Please find the attached sample application and feel free to let me know if you have any further questions on this matter.
Thank you so much for your quick response. It will be help me to achieve my actual goal.. if any additional information required will let you know.
Once again my sincere thanks to you.. :) :)
I am glad I was able to help. Please do not hesitate to let me know if you have any further questions on this matter.
I have done the small changes in solution which you have provided. It is similar to my actual requirement. but one small change in that. how can I remove the bottom line.no need to display the bottom line.
Any suggestions please let me know.
https://drive.google.com/file/d/0B867YMLkegUJdHpsN0pTb1BZSVU/edit?usp=sharing
Hello Gergana,
Could you please help on this above post.
Thank you.
Regards.
I have been further researching your question. Currently the entire blue line that you are seeing around the XamRadialGauge is one whole path. When you remove it the upper part disappears too.
You can suggest a new product idea for this functionality. New Product Ideas for future versions (or vote for existing ones) can be created at http://ideas.infragistics.com.
Steps to create your idea:
The benefits of submitting the product idea yourself include:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
Additional benefits of the Product Idea system include:
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
The product ideas site allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
Could you please provide the code in windows phone as i am unable to get the similar UI.
Could you please help on this. Any sample..?
I have been looking into your question. The sample application I have provided uses the new Infragistics XamRadialGauge. It is available since Infragistics 13.2. This gauge has a property BackingShape, that lets the developer to change the shape of the gauge.
In Windows Phone you would find the old XamRadialGauge, which does not have a BackingShape property.
What I can suggest is to log a new product idea, on the web site I have mentioned in my previous post, for the new XamRadialGauge to be available for Windows Phone too.
