Hi @all
we just installed release 14.1.20141.2059 of the Windows Forms controls and observed a problem, that was not present with Version 13.2.
If we set the same value for an UltraOptionSet twice, the value becomes null.
e.g. UltraOptionSet has initial value 0
UltraOptionSet.Value = 1; // Value becomes 1
UltraOptionSet.Value = 2; // Value becomes 2
UltraOptionSet.Value = 2; // Value becomes null
Is this a known issue?
Best regards,
Alex
Hello Alex,
Thank you for contacting Infragistics.
I created the attached sample to test the issue you described. It contains an UltraOptionSet with several items and a button. When the button is clicked, the UltraOptionSet.Value property is set to 2 and the value of the Value property is printed to Visual Studio's Output window. When I run the sample, 2 is printed to the Output window every time the button is clicked.
I'd like you to compare my sample with yours. If you're not able to determine why your sample is showing the behavior you described, please zip up your project and attach it to this thread.
Hello Dave,
thank you for four fast reply. Attached please find "my" example. Indeed it's yours. I only changed the DataType of the Items to 16 bit signed int (and not 32 bit) to produce the problem.
Best regards
