I have a datasource which composes of an IBindingList POCO that is dynamically updated with custom property descriptors. The data is rendered correctly, but for some reason or another, I am getting two sets of data headers!! The headers are identical and where it appears varies depending on the rate of update to the IBindingList data source.
Ooops!
My link did not work for some reason from my Google Drive! Here is the image from the above post.
Hello Ed and thank you for posting!
I have been looking into your scenario and tried to reproduce the behavior you have described in a sample project. It seems that no multiple headers are displayed with version 14.1.20141.2108. Would you please modify the attached project so I could investigate it further? Which version of Infragistics controls you are using?
