I need yet another help!!
I am dealing with Hierachial XamGrid in which I want to bind header text of a TextColumn in xamGrid to a variable in ViewModel (I am using MVVM architecture).
That is if I select 'April' in a combo box(combo bos is not a part of the grid) then Header Text of textColumn in XamGrid should be 'Net Movement for April'; If I select 'September' in the combo box then the Header Text should change to 'Net movement for September'.
How to do this in Silverlight Infragistics.
Thanks!!
Hi Ritika,
Thank you for your post. I have been looking into your requirement and I created a sample application(XamGridCombo.zip) that shows the desired functionality.
Please let me know, if you need any further assistance on this matter.
