hi
I use ultratexteditor. when I input it righttoleft character and digit together, show me:
12345الف
all digit in left and alphabet in right
how I do fix it?
Hello Fatemeh,
Thank you for posting in our forums!
I have tried to reproduce your issue on my side, and I am not sure that I am seeing issue here. I’ve tested Infragistics UltraTextEditor and standard MS TextBox and both components works on the same way. When you type successively “الف12345” the result you expect “12345الف”. The numbers are not in the opposite order of the typing, since they are in decimal notation, which meant that the position of the digit determines the value, changing the order of the digits in the number changes its value. So if this is the issue, it is expected behavior. Please let me know if you have any further questions or if I misunderstood you.
when I typed
23الف12
show me
hi thanks
this issue fixed by AlwaysInEditMode = true
but if this text insert into cells of Infragistics.Win.UltraWinGrid.UltraGrid
text shown not correctly:
الف1223
When the cell is not in edit mode, the UltraGrid draws the text using GDI+, which is what Microsoft DotNet uses. When the cell goes into edit mode, it is showing an inner TextBox control which uses GDI. There is no way to force the inner TextBox to use GDI+, but alternatively you can set up the UltraGrid to use GDI. As older graphic device interface, GDI is a bit slower than GDI+ but you have to fill the UltraGrid with more complex data, in order to notice the difference. For further reference about what is the new in GDI+, please refer to the following Microsoft`s article:
http://msdn.microsoft.com/en-us/library/windows/desktop/ms533797%28v=vs.85%29.aspx
Therefore in order to fit your requirements, look for the UltraGrid`s property TextRenderingMode and change it to GDI. This also works for the UltraTextEditor and any control that has TextRenderingMode property.
I am waiting for your feedback.
hi thanks , my issue is fixed
I am glad that you were able to solve this issue.
Please let me know if you need any further assistance on it.
Thank you for using Infragistics Components!
hi I use infragistics 14
when I set righttoleft = true for example in ultralable and set text = : نام کاربری
this text shown:
نام کاربری:
in latest version this shown correctly
I use infragistics 14 when I set righttoleft = true for example in ultralable and set text = : نام کاربری
this text shown: نام کاربری:
but in latest version this shown correctly
Thank you for your feedback. I am glad to hear that you find proper solution for your issue, and everything works with the latest service release of Infragistics 14.1.
hi I use infragistics 14.1
when I set righttoleft = true for example in ultralable and set text = : نام کاربری this text shown
how to fix it?
