How would I format dates as datetime, and how should the var data be formatted. I understand they're two ways to handle dates, as numeric and as datetime?
Datetime Value1 Value2 Value3
09/10/2014 11:40:11 1 2 3
09/10/2014 11:41:11 1 2 3
09/10/2014 11:42:11 1 2 3
09/10/2014 11:43:11 1 2 3
...........Code Snippet....................
<script type="text/javascript"> $(function () { var data = [ ??? ];
$("#chart").igDataChart({ width: "500px", height: "500px", dataSource: data, axes: [ { name: "Datetime", type: "numericX" },
{ name: "yAxis", type: "numericY" }], series: [{ name: "series1", title: "Test Series", type: "line", xAxis: "Date", yAxis: "yAxis", valueMemberPath: "Value1" }], horizontalZoomable: true, verticalZoomable: true, windowResponse: "immediate", overviewPlusDetailPaneVisibility: "visible" }); }); script>
Hello John,
Thank you for contacting Infragistics community.
I prepared a sample that demonstrates igDataChart with Date type displayed on X axis. Please note that in order to be able to format the Date label, your data source should be configured as following:
var data = [ { "Date": new Date(), "Value": 1000 }, { "Date": new Date(), "Value": 995 }, { "Date": new Date(), "Value": 925.5 }, { "Date": new Date(), "Value": 940.25 }, { "Date": new Date(), "Value": 1020.5 } ];
And you can use formatLabel function to format the X axis label like demonstrated in the documentation: http://help.infragistics.com/jQuery/2014.1/ui.igDataChart#options:axes.formatLabel
Please take a look at the attached sample and let me know if you have further questions.
Tsanna
