hello,
i want to know how can i represent the org-chart according to the levels request,
we have huge data, i want to display only the levels of chart according to the choices of users(i know i can control that from the data but in our scenario we need control that from the org-chart).
thank you
Hello ehabows,
Thank you for your post!
I have been looking into your post and have created a small sample application for you. There is a property MaxDepth of the XamOrgChart, that can be set to define the visible hierarchies. More about this property you can find on the following link from our documentation: http://help.infragistics.com/Help/Doc/Silverlight/2014.1/CLR4.0/html/xamOrgChart_Maximum_Node_Depth.html.
In the sample application I have implemented the above mentioned functionality for you. Please find the attachment and feel free to let me know if you have any further questions on this matter.
thank you for your fast support,
it's working perfectly now, but i got another issue, i was display the node count by the below method,
private int GetNodeCount(Infragistics.Controls.Maps.OrgChartNode node){ int count = 0; if (node != null) { count = 1; foreach (var childNode in node.ChildNodes) { count += GetNodeCount(childNode); } } return count;}
and when i use the MaxDepth property the count is not correct, i got the count of all nodes not the displayed nodes only
Thank You
Ehab
