Hi All,
We have a requirement with respect to column header movement of the Infragistcs Grid (Xamdatagrid). Here, if we move a column, the data part of the column shouldn’t be moved whereas the header alone should be moved. Infragistics grid supports field / column movement, however, we need to find a way to move only the header.
I tried to handle FieldPositionChanging event, but no luck. Your help is highly appreaciated!
Thanks.
Hello Krishnan,
It is expected behavior that the data for a column moves when the header is moved otherwise without this behavior it would be difficult for an end user to know what they are looking as the data could be mislabeled by the rearrangement of headers.
Please provide me with more information on the business need you are trying to accomplish so that I can be of further assistance in helping you find an appropriate solution.
Sincerely,
Valerie
Developer Support Supervisor - XAML
www.infragistics.com/support
Were you able to resolve your issue?
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
Hi Valerie,
Thanks for your reply. We got a workaround for this and implemented a dropdowns in the header. It worked fine and we were able to complete the functionality. Thanks again !
Thank you for the update. I am glad you were able to find a resolution to your issue.
