HiI have a ultrawingrid consisting of two binded checkbox columns only. I want to make those columns mutually exlusive so if i check one the other have to be unchecked. To achieve that i am using AfterCellUpdate event to update the binded object, this is working fine except that this event does not fire until the user leave the cell and i want to perform the update the object and refresh the control after the user had checked or unchecked any checkbox.Question i short, can the object be updated and the grid row refreshed just after the user check\uncheck each cell?
Hello Elio
I am just checking about the progress of this issue. Let me know if you need my further assistance on it.
Sincerely,
Milko
Developer Support Engineer
www.infragistics.com/support
