Finally chased this one down but it appears that in the 14.1.20141.2059 release (and previously to this as I have been hitting this for some time now but not been able to research further) that the FixedRows Collection isn't properly being cleared behind the seen and after applying a new DataSource it throws an internal index error when it attempts to fix a row that no longer exists. Previously (I have no clue when the UltraGrid stopped doing this) when you reset the Datasource the Grid cleared the Fixed Collection and you didn't have to worry about it...this is no longer the case. If I programmatically clear the Fixed Rows Collection as expected I get no error.
-Ian
Actually I am not sure if the error is coming from the fact that the row no longer exists or currently exits and the "re-fixing" of it is having trouble. In any case the following worked on my end of things:
//Always Clear Fixed Rows To Avoid ErrormyGrid.Rows.FixedRows.Clear();
//Set New DatasourcemyGrid.DataSource = _dtJobData; //Process Flagged RecordsFlagRecords();
The FlagRecords routine in my code processes records that have been assigned to specific users and "flags" aka "fixes" them to the top of the grid automatically. I am going to venture that this has been an issue for roughly two or so years now but I haven't been able to research in depth to figure out where it was happening so I handled things differently. If you need me to build a sample application w/ data to prove this I would be more than happy to do this as this has helped before to show "unique" issues like this.
Hello Ian,
Thank you for contacting Infragistics.
I created the attached sample to test this issue, but I did not reproduce it.
Please take a look at it and modify it so it does reproduce the issue. Once you have done so, please attach the modified sample to this thread so I can log this issue with our developers.
Please let me know if you have any other questions about this.
