when you have a pivot grid bound to a FlatDataSource and you have one or more 'filters' tied to the datasource...
is it possible to retrieve the selected values of the filters dropdown when they are selected?
is it possible to retrieve what values are selected when you handle the CellDoubleClicked event?
thanks
When handling the CellDoubleClicked event, you can find which values are in the selected cell by calling e.Cell.Control.Content. Just as a warning, you will want to check whether or not e.Cell.Control.Content is null before doing this to avoid an exception.
For the filter bit, I am somewhat unsure of what you are asking, but if you are referring to the filter that is on the left side of the labels that go into the column and row area, then I would recommend implementing and merging the default styles for the XamPivotGrid. A common place to find these default styles is the following directory:
C:\Program Files (x86)\Infragistics\2014.1\Silverlight\DefaultStyles\XamPivotGrid
After merging the file named generic.xaml and adding the generic_shared.xaml file as well, scroll down to the near-bottom of the generic_shared default style and find a Style targeting igPivotPrim:FilterFieldItemControl BasedOn {StaticResource ExpandableFieldItemControlKey}. In this style there is a XamDataTree named FilterTree.
If you move this style into your project, you can handle the NodeCheckedChanged event of that FilterTree and using e.Node.Control.Content in the handler, you can retrieve the selected filters as they are selected.
I have attached a sample application demonstrating the above.
Sincerely,AndrewDeveloper Support Engineer IInfragistics Inc.www.infragistics.com/support
Just checking in, did you have any other questions or concerns on this matter?
