How can I set the toolTipPosition without using the categoryToolTipLayer? I want it to always align itself at the top so that it will display everything that it needs to, but right now it display slightly below and to the right of the cursor.
Hello rsimm,
Thank you for contacting us.
As I understand you want to change the tooltip position of igDataChart. My suggestion is to use toolTipPosition option, as it is shown in our online sample below:
http://igniteui.com/data-chart/category-tooltip-layer
Code snippet:
$("#tooltipPos").change(function (e) { var position = $(this).val(); $("#chart").igDataChart("option", "series", [{ name: "categorySeries", toolTipPosition: position }]); });
I can't seem to make this work on a Stacked Column Series.
