I'm using ultratoolbarmanager. I set property formDisplaystyle = standardwithribbon and IsGlassSupport = false. How can i set backcolor for title of form, backcolor, hottrackcolor for minimize, maximize, close button?
Thanks!
Hello Ba Ngoc,
You can customize your Form Non-Client area with WinToolbarsManager and with WinFormManager. Please note the properties you have control while using WinToolbarsManager are less than the ones via WinFormManager. More about customizing the Form Non-Client area with WinToolbarsManager and with WinFormManager you can find by following next links http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=WinToolbarsManager_Customizing_Non-Client_Area_with_WinToolbarsManager.html and http://help.infragistics.com/Help/Doc/WinForms/2014.2/CLR4.0/html/WinFormManager_Customize_a_Form_with_WinFormManager.html
As you need to customize minimize, maximize and close buttons appearance and you use WinToolbarsManager my suggestion is to make your styling with Infragistics AppStylist. It is easy and convenient way to apply any custom styling to your application. Please find attached a sample solution loading run time AppStylist allowing you to set entire style of your application. More about AppStylist you can find by following the next llink http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Styling_Guide_Styling_Your_Application.html
Please check my solution and let me know if this is what you are looking for or if I am missing something.
Hi Milko,
My form is MDI parent. So, i can not use winformmanager.
You may use same approach even if you use MDI Parent form. Please note to be able to design minimize, maximize and close buttons you need to add UltraFormManager to your child form.
Please find attached a sample solution implementing this approach.
Please let me know if this is what you are looking for or if I am missing something.
