The app can browse the structure of the site but when I get try to download a document I get a connection error after about 2 mins of waiting
In order to get more context information I will need you to reply to some questions.
To troubleshoot this further I require technical logs produced from SharePlus. Please follow steps here, after reproducing the issue a few times.
http://www.infragistics.com/community/forums/t/73340.aspx
Gonzalo TTechnical Support Engineer IEnterprise MobilityInfragistics Inc.
Hi Please see responses below. Also for information our sharepoint server sits behind an ISA Server if that makes any difference. Where do I send the logs to?
Paul
Paul,
We will need you to send us the app logs in order for us to get further information on the error.
Please click here and follow the steps in that forum post in order to enable and send us SharePlus' technical logs after reproducing the issue a couple of times.
We will also like to know what's the size of the file.
Gonzalo TTechnical Support Engineer IEnterprise MobilityInfragistics, Inc.
Hello Paul,
I'm writing to you in order to check on the app's performance.
Is SharePlus working properly?
We haven't received any updates from you and we will be closing this support case in the next 72 hours if we don't hear back from you. You can reopen the case up until 30 days after it has been closed.
I'm writing to let you know that we are closing this support case.
Bare in mind that you can reopen this support case within the next 30 days.
Please let us know if there's anything else that we can do for you.
