425
Adding multiple rows to Infragistics webdatagrid without hitting database
There is a requirement, where I should add all the selected items from an asp:datagrid to infragistics webdatagrid without hitting the database.
I had used grid.get_rows().add(new_row) to add all the selected items to infragistics webdatagrid.
However I see that only the first selected item is added while the other selected items are not added.
Your help is very much appreciated.
Please find the code snippet.
function CopyPrev() {
    var tbl = document.getElementById("dgPrev"), chkd, isbn, title, prn, subacct, type;
       for (var i = 1; i < tbl.rows.length; i++) {
        chkd = tbl.rows[i].cells[0].innerHTML;
        if (("" + window.event) == "undefined") {
            type = "FF";
            if (tbl.rows[i].cells[0].childNodes[1].childNodes[0].checked) {
                chkd = "CHECKED";
            else {
                chkd = "";
        else {
            type = "IE";
                chkd = "CHECKED";
            else {
                chkd = "";
        if (chkd.search("CHECKED") != -1) {
            if (type == "IE") {
                isbn = ExtractString(tbl.rows[i].cells[1].innerText);
            else {
                isbn = ExtractString(tbl.rows[i].cells[1].childNodes[1].innerHTML);
            if (isbn.length > 8) {
                if (type == "IE") {
                    title = ExtractString(tbl.rows[i].cells[2].innerText);
                    prn = ExtractString(tbl.rows[i].cells[3].innerText);
                    subacct = ExtractString(tbl.rows[i].cells[4].innerText);
                else {
                    title = ExtractString(tbl.rows[i].cells[2].childNodes[1].innerHTML);
                    prn = ExtractString(tbl.rows[i].cells[3].childNodes[1].innerHTML);
                    subacct = ExtractString(tbl.rows[i].cells[4].childNodes[1].innerHTML);
                if (ISBNDupeSearch(isbn, subacct, prn) == false) {
                    var gGrid = $IG.WebDataGrid.find('uwgTime');
                    var new_row = [gGrid.get_columns().get_length() - 4];
                    new_row[0] = isbn
                    new_row[1] = title
                    new_row[2] = prn
                    new_row[3] = subacct
                    for (var j = 4; j < gGrid.get_columns().get_length() - 4; j++) {
                        new_row[j] = 0;
                    gGrid.get_rows().add(new_row);
The dgPrev is the asp:Datagrid.
uwgTime is infragistics webdatagrid
The first loop is to select all the chosen items from the table and add it to infragistics webdatagrid.
The seccond loop is to add zeros to empty columns in the array of new_row.
Please let me know if any further details are required
Parents Reply Children
