365
Dates in Grid are displaying an offset
I've been noticing that whatever date we are passing into the igGrid is off by 1 day.  Upon closer inspection, we've found out that our are set at midnight (for example 10/30/2012 12:00:00), but the date is then offset by our timezone.  The final date by the time it is entered into the grid is 4 hours prior (with our example, the date in the grid would be 10:29/2012 20:00:00).  Is there anyway to freeze or set the timezone for dates?
Thanks.
Parents
  • 17559
    Hello Patrick ,
    I have been looking into  your question and I believe that the mentioned behavior  is caused by a known issue in our control. Therefore I created a new support ticket for you in our system with number CAS-103683-P9G3Y9 and I linked it to issue 120485. This way you will be automatically notified when the resolution for the issue is available. I will provide you with more details through the mentioned support ticket.
Reply Children
No Data
