4155
How can i change icon for Nodes in XamDataTree depending on if the Node is expanded?
As the question says, i want to use an image of an open folder if the node is expanded, and a closed folder if the node is not expanded.  I have a DataTemplate already, but can'tfigure out how to make a trigger for this that depends of the node's IsExpanded property.  Here's my existing XAML, showing an icon but without any code for switching the image source:
<igDT:NodeLayout Key="ReportFolder" TargetTypeName="ReportFolder" DisplayMemberPath="FolderName" >
                                            <igDT:NodeLayout.ItemTemplate>
                                                <DataTemplate>
                                                    <StackPanel Orientation="Horizontal" >
                                                        <Image Source="/Resources/Icons/closed_folder.png" /> //this is where I need a trigger to select open_folder.png if IsExpanded
                                                        <TextBlock Text="{Binding Data.FolderName}"/>
                                                    </StackPanel>
                                                </DataTemplate>
                                            </igDT:NodeLayout.ItemTemplate>
                                        </igDT:NodeLayout>
Parents
No Data
Reply
  • 34430
    Verified Answer
    Hello Travis,
    Rather than defining a NodeLayout.ItemTemplate, I would recommend that you look into the ExpandedIconTemplate and CollapsedIconTemplate values of the XamDataTree. If you set these to a DataTemplate with an Image inside, they will change based on whether the node is expanded or collapsed.
    Sincerely,
    Andrew
    Developer Support Engineer I
    Infragistics Inc.
    www.infragistics.com/support
Children
No Data
