I am using SQL server with my application. I need to create Pivot tables in various formats. I am not sure if a binding between a SQL database and the Pivot control is possible, but if it is can you please help me with sample code to achieve something like I did with the code below
Public Sub FIllGrid()
Dim cmd As New SqlClient.SqlCommand
cmd.Connection = con
Dim Table As New DataTable
If con.State = ConnectionState.Closed Then
con.Open()
End If
cmd.CommandText = " SELECT distinct QUALIFICATION.[SETA] as [SETA] " & _
", " & _
"SUM(CASE " & _
"WHEN STUDENT.[Gender_Code] ='M' and " & _
"QUALIFICATION.[DateRegisRes] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [MALE] " & _
"WHEN STUDENT.[Gender_Code] ='F' and " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [FEMALE] " & _
"WHEN STUDENT.[Equity_Code] ='BA' and " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [BA] " & _
"WHEN STUDENT.[Equity_Code] ='BC' and " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [BC] " & _
" " & _
"WHEN STUDENT.[Equity_Code] ='BI' and " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [BI] " & _
"WHEN STUDENT.[Equity_Code] ='WH' and " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [WH] " & _
"WHEN STUDENT.[Equity_Code] ='U' and " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [U] " & _
"WHEN Student.[Gender_Code] ='M' and " & _
"QUALIFICATION.[DatecompRes] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [MALE 2] " & _
" , " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [FEMALE 2] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [BA 2] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [BC 2] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [BI 2] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [WH 2] " & _
"BETWEEN @StartDate and @EndDate THEN 1 ELSE 0 END) as [U 2] " & _
"FROM (STUDENT JOIN QUALIFICATION ON " & _
"QUALIFICATION.[ID] = STUDENT.[ID] ) where QUALIFICATION.[SETA] <> '' " & _
" and QUALIFICATION.[SETA] <> 'STUDENT REGISTRATIONS' " & _
"GROUP by QUALIFICATION.[SETA] order by QUALIFICATION.[SETA] "
cmd.Parameters.AddWithValue("@StartDate", StartingDate)
cmd.Parameters.AddWithValue("@EndDate", EndingDate)
cmd.CommandType = CommandType.Text
Table.Load(cmd.ExecuteReader())
UltraGrid1.DataSource = Table
If Table.Rows.Count > 0 Then
btnExcelExport.Enabled = True
If con.State = ConnectionState.Open Then
con.Close()
End Sub
Hi Marius,
Thank you for contacting Infragistics Developer Support.
You can use our new FlatDataSource that was added in 14.2 in order to do that. You will need to create an IEnumerable collection out of the DataReader and provide that to the FlatDataSource. After that you can see how to use the FlatDataSource with UltraPivotGrid from this thread:
http://help.infragistics.com/Doc/WinForms/2014.2/CLR4.0/?page=WinPivotGrid_Using_FlatDataSource.html
I have attached a sample using local database in order to demonstrate this suggestion.
Please let me know if you have any additional questions.
HI Dimitar
Ok, I had a look at the example and I understand the basic working of it. I am just not sure how to create an IEnumerale from my Table..
Will I create a DataTable like in my code and then create the IEnum ?
Can you give me a simple example of that , please
Thank you
Thank you for the reply.
In the sample, I have created the IEnumerable from the DataReader object that you get from the ExecuteReader() method of the SqlCommand class:
Dim reader = cmd.ExecuteReader()
Then I iterate all of the DataRecords in the reader and I create SportsData objects for each of the DataRecords (I have changed the statement to use the column names, instead of the indexes):
Dim listOfSportsData = reader.Cast(Of IDataRecord).
Select(Function(s) New SportsData(s.Item("Sport"), s.Item("City"),
s.Item("Nation"), s.Item("Budget"), s.Item("Players"))).ToList()
If you want to use the data table itself, the algorithm would be similar, you need to iterate the rows and then for each row create an object from your data class.
Another option would be to actually use LINQ to SQL for the PivotGrid. This will allow you to use strongly typed objects from your database and the IQuerryable type that is returned by the LINQ queries can be easily turned into IEnumarable by using AsEnumearable method.
I hope this makes everything clear. Please let me know if you have any additional questions.
Hi , I tried to convert you r example to suit my needs. This is my code.. In the end I want to use 2 JIONED tables. In my SQL statement, do I only have to give the names of the fields I am using, or can I use SELECT * ?
Imports System.Data
Imports System.IO
Imports System.Data.SqlClient
Imports Infragistics.Olap.FlatData
Public Class PivotTableExample
Dim counter As Integer = 0
Public con As New SqlConnection(constr)
Public adp As SqlDataAdapter
Public dt As New DataTable
Public cmd As SqlCommand
Public StartingDate, EndingDate As Date
Dim workbook As Infragistics.Documents.Excel.Workbook
Public Sub FillPivotGrid()
Dim query As String = " SELECT * FROM STUDENT "
Using conn As New SqlConnection(constr)
Using cmd As New SqlCommand(query, conn)
conn.Open()
Dim data As IEnumerable(Of SETA_Qualifications) = CreateIEnumerable(reader)
Dim ds As FlatDataSource = InitializePivotData(data)
Dim parameters = New CubeGenerationParameters()
ds.GenerateCube(parameters)
ds.InitializeAsync(UltraPivotGrid1)
UltraPivotGrid1.DataSource = ds
OlapDataSelector1.DataSource = ds
End Using
Private Function CreateIEnumerable(reader As SqlDataReader) As IEnumerable(Of SETA_Qualifications)
Dim listOfSETA_Qualifications = reader.Cast(Of IDataRecord).
Select(Function(s) New SETA_Qualifications(s.Item(1), s.Item(2), s.Item(3), s.Item(4), s.Item(5), s.Item(6)))
Return listOfSETA_Qualifications
End Function
Private Function InitializePivotData(data As IEnumerable(Of SETA_Qualifications)) As FlatDataSource
Dim itemSource As IEnumerable(Of SETA_Qualifications) = data
Dim settings = New FlatDataSourceInitialSettings()
Dim ds = New FlatDataSource(itemSource.ToList(), GetType(SETA_Qualifications), settings)
AddHandler ds.InitializeHierarchyDescriptor, AddressOf ds_InitializeHierarchyDescriptor
AddHandler ds.AggregateMeasure, AddressOf ds_AggregateMeasure
settings.Rows = "[SETA_Qualifications].[Person_Title]"
settings.Columns = "[SETA_Qualifications].[Equity_code]"
settings.Measures = "[Measures].[Gender]"
Return ds
Private Sub ds_InitializeHierarchyDescriptor(sender As Object, e As InitializeHierarchyDescriptorEventArgs)
Dim level As LevelDescriptor = e.HierarchyDescriptor.LevelDescriptors.ToList().FirstOrDefault(Function(lvl) lvl.Name = "all")
If level IsNot Nothing Then
Select Case e.HierarchyDescriptor.PropertyDescriptor.Name
Case "Person_Title"
level.MemberProvider = Function(item) "All Persons"
Case "Equity_code"
level.MemberProvider = Function(item) "All Equity"
Exit Select
Case "National_Id"
level.MemberProvider = Function(item) "All ID"
End Select
Private Sub ds_InitializeMeasureDescriptor(sender As Object, e As InitializeMeasureDescriptorEventArgs)
If (e.MeasureDescriptor.Name = "Gender") Then
e.MeasureDescriptor.DisplayFormat = "$#"
e.MeasureDescriptor.Aggregation = MeasureAggregation.Count
Private Sub ds_AggregateMeasure(sender As Object, e As AggregateMeasureEventArgs)
If e.MeasureDescriptor.Name = "Gender" Then
Dim total As Double = 0.0F
Dim count As Double = 0.0F
For Each o As Object In e.Items
Dim item = TryCast(o, SETA_Qualifications)
If item IsNot Nothing Then
total += item.Gender
count += 1.0F
Next
e.Value = total / count
e.Handled = True
Private Sub UltraButton1_Click(sender As Object, e As EventArgs) Handles UltraButton1.Click
FillPivotGrid()
End Class
Class SETA_Qualifications
Private m_Person_Title As String
Private m_Equity_code As String
Private m_National_Id As String
Private m_Gender As String
Private m_Disability_Status As String
Public Sub New(OFO_Code As String, SETA As String, ProgramName As String, National_Id As String, Gender As String, Disability As String)
Me.m_Person_Title = Person_Title
Me.m_Equity_code = Equity_code
Me.m_National_Id = National_Id
Me.m_Gender = Gender
Me.m_Disability_Status = Disability
<System.ComponentModel.Category("Person_Title")>
Public Property Person_Title As String
Get
Return m_Person_Title
End Get
Set(value As String)
m_Person_Title = value
End Set
End Property
<System.ComponentModel.Category("Equity_code")>
Public Property Equity_code As String
Return m_Equity_code
m_Equity_code = value
<System.ComponentModel.Category("Identification")>
Public Property Identification As String
Return m_National_Id
m_National_Id = value
<System.ComponentModel.Category("Metrics")>
Public Property Gender As Double
Return m_Gender
Set(value As Double)
m_Gender = value
Public Property Disability As Integer
Return m_Disability_Status
Set(value As Integer)
m_Disability_Status = value
I get the following Error message:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.InvalidCastException: Conversion from type 'DBNull' to type 'String' is not valid. at Microsoft.VisualBasic.CompilerServices.Conversions.ToString(Object Value) at WindowsApplication1.PivotTableExample._Lambda$__1(IDataRecord s) in C:\College Placement Program\StudentPlacement\StudentPlacement\PivotTableExample.vb:line 46 at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext() at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source) at WindowsApplication1.PivotTableExample.InitializePivotData(IEnumerable`1 data) in C:\College Placement Program\StudentPlacement\StudentPlacement\PivotTableExample.vb:line 53 at WindowsApplication1.PivotTableExample.FillPivotGrid() in C:\College Placement Program\StudentPlacement\StudentPlacement\PivotTableExample.vb:line 34 at WindowsApplication1.PivotTableExample.UltraButton1_Click(Object sender, EventArgs e) in C:\College Placement Program\StudentPlacement\StudentPlacement\PivotTableExample.vb:line 291 at System.Windows.Forms.Control.OnClick(EventArgs e) at Infragistics.Win.UltraControlBase.OnClick(EventArgs e) at Infragistics.Win.Misc.UltraButtonBase.OnClick(EventArgs e) at Infragistics.Win.Misc.UltraButton.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18449 built by: FX451RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll----------------------------------------StudentPlacement Assembly Version: 1.0.5420.20349 Win32 Version: 1.0.* CodeBase: file:///C:/College%20Placement%20Program/StudentPlacement/StudentPlacement/bin/Debug/StudentPlacement.exe----------------------------------------Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 11.0.50709.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll----------------------------------------System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18046 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18022 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------System.Runtime.Remoting Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34107 built by: FX45W81RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll----------------------------------------Infragistics4.Documents.Reports.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Documents.Reports.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Documents.Reports.v14.2.dll----------------------------------------Infragistics4.Win.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.v14.2.dll----------------------------------------Infragistics4.Shared.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Shared.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Shared.v14.2.dll----------------------------------------System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18046 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.34230 built by: FX452RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18058 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------Infragistics4.Win.UltraWinDataSource.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinDataSource.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinDataSource.v14.2.dll----------------------------------------Infragistics4.Win.Misc.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.Misc.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.Misc.v14.2.dll----------------------------------------UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll----------------------------------------Infragistics4.Win.UltraWinGrid.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinGrid.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinGrid.v14.2.dll----------------------------------------Infragistics4.Win.SupportDialogs.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.SupportDialogs.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.SupportDialogs.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinGrid.ExcelExport.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinGrid.ExcelExport.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinGrid.ExcelExport.v14.2.dll----------------------------------------Infragistics4.Documents.Excel.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Documents.Excel.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Documents.Excel.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinPrintPreviewDialog.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinPrintPreviewDialog.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinPrintPreviewDialog.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinGrid.DocumentExport.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinGrid.DocumentExport.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinGrid.DocumentExport.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinToolbars.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinToolbars.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinToolbars.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinStatusBar.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinStatusBar.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinStatusBar.v14.2.dll----------------------------------------Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.Transactions Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll----------------------------------------System.EnterpriseServices Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll----------------------------------------System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll----------------------------------------Infragistics4.Win.UltraWinTabControl.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinTabControl.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinTabControl.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinEditors.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinEditors.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinEditors.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinSchedule.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinSchedule.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinSchedule.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinPivotGrid.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinPivotGrid.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinPivotGrid.v14.2.dll----------------------------------------Infragistics4.Olap.DataSource.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Olap.DataSource.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Olap.DataSource.v14.2.dll----------------------------------------Infragistics4.Win.UltraWinTree.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Win.UltraWinTree.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Win.UltraWinTree.v14.2.dll----------------------------------------Infragistics4.Olap.Core.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Olap.Core.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Olap.Core.v14.2.dll----------------------------------------Infragistics4.Documents.Core.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Documents.Core.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Documents.Core.v14.2.dll----------------------------------------WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18058 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll----------------------------------------Infragistics4.Olap.DataSource.Flat.v14.2 Assembly Version: 14.2.20142.2010 Win32 Version: 14.2.20142.2010 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Infragistics4.Olap.DataSource.Flat.v14.2/v4.0_14.2.20142.2010__7dd5c3163f2cd0cb/Infragistics4.Olap.DataSource.Flat.v14.2.dll----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
It seems that the error happens because some of your columns allow null values and those can’t be converted to String. So what you could do in order to fix this is to add logic in the CreateIEnumerable method, which checks if Item(1), Item(2), etc. is equal to DBNull and if it is to use the default value for the value type instead. Note that those checks has to be implemented for columns of your database, where null values are allowed.
As for the queries, I have used SELECT * for simplicity, as an example. If you are joining two tables you should use the name of the fields that you are requesting.
I have tried the following code... still does not load the pivot... gives an error
Select(Function(s) New SETA_Qualifications(IIf(IsDBNull(s.Item(1)), "", s.Item(1)), IIf(IsDBNull(s.Item(2)), "", s.Item(2)), IIf(IsDBNull(s.Item(3)), "", s.Item(3)), IIf(IsDBNull(s.Item(4)), "", s.Item(4).Value), IIf(IsDBNull(s.Item(5)), "", s.Item(5)), IIf(IsDBNull(s.Item(6)), "", s.Item(6))))
I am still struggling with this. THe Error is now fixed, I removed the .Value.
The Grid is NOT populated with any items. Am I checking the Items correctly? How else can I check if the item contains a DBNULL valiue?
Select(Function(s) New SETA_Qualifications(IIf(IsDBNull(s.Item(1)), "", s.Item(1)), _
IIf(IsDBNull(s.Item(2)), "", s.Item(2)), _
IIf(IsDBNull(s.Item(3)), "", s.Item(3)), _
IIf(IsDBNull(s.Item(4)), "", s.Item(4)), _
IIf(IsDBNull(s.Item(5)), "", s.Item(5)), _
Anybody that can help me? I need to populate the PivotGrid... but my code above does not do tht
