Hi, here I have created the datatable dt,and attached to datasource i.e ultraGrid1.datasource =dt so,i dont have any dadadapter or dataset,so how can i save the data in the ultragrid drag and droped rows on the button click event.
Thank you for contacting Infragistics Support.
In order to save changes you have made to your UltraGrid you need to call its UpdateData method. This method will update any modified information in the grid, sending it to the data provider. More about UpdateData methos you may find by following the next link http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Infragistics4.Win.UltraWinGrid.v14.2~Infragistics.Win.UltraWinGrid.UltraGridBase~UpdateData.html. You can also set when the grid will update its data source by setting UpdateMode property of the grid. More about this property you may find by following the next link http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Infragistics4.Win.UltraWinGrid.v14.2~Infragistics.Win.UltraWinGrid.UltraGrid~UpdateMode.html
Please note the grid only deals with its local DataSource, and the DataSource only get updates by the grid when something changes. When dealing with the DataSource and the back end (the database), the grid doesn't really have any involvement there. If you need to save the changes you have made in DataTable you need to use some back end. Please find attached sample where I have implemented saving the changes from UltraGrid to DataTable. Additionally when you click “Save Data To XML” button DataTable will be saved in XML file.
Please let me know if this is what you are looking for or if I am missing something.
hi,i have tried like this
{DataTable dt = new DataTable(); dt.Columns.Add("CustomerName",typeof(string)); dt.Columns.Add("CustomerID", typeof(int));
ultragrid1.Datasource=dt; }
private void ultraButton1_Click(object sender, EventArgs e) {
this.ultraGrid1.UpdateData(); DataTable dt = (DataTable)this.ultraGrid1.DataSource; }
created the data table dt,and performed drag and drop operation ,now on click of button data should save in ultragrid.
plzz help me to get the problem resolve
Thank you for your feedback.
You are on the right way. When you set data source of the grid to a data table this will cause the grid to synchronously load the data source. More about DataSource property you may find by following the next link http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Infragistics4.Win.UltraWinGrid.v14.2~Infragistics.Win.UltraWinGrid.UltraGridBase~DataSource.html
After the grid is bound to the data table every change made in the grid will be populated in the data table. If at this point you close your application all the changes will be lost as you did not save them in the back to the data source (your DataBase). In order to save your changes you need some kind of back end storage as database, XML file and etc. After you set up your back end data storage you should save your data from the updated DataTable object back to the database. Final step is when you start your application to check if you have data in your data storage. If so you need to load data from the data storage.
Please let me know what your back end data storage is. What I saw in your code snippet is you did not save your data to any type of back end storage, nor you tried to load from one.
Waiting for your feedback.
