Hi Team,
Not able to use the .Net textbox (any controls ) inside the ultrawin grid cell and it says Editor component property not available
private void ultraGrid_InitializeLayout(object sender, InitializeLayoutEventArgs e)
Textbox text = new Textbox;
e.Layout.Bands[0].Columns[3].EditorComponent = text;
whlie run the application getting the below error.
'Infragistics.Win.UltraWinGrid.UltraGridColumn' does not contain a definition for 'EditorComponent' and no extension method 'EditorComponent' accepting a first argument of type 'Infragistics.Win.UltraWinGrid.UltraGridColumn' could be found (are you missing a using directive or an assembly reference?)
What version of the controls are you using? If you have an older version, you might not have the EditorComponent property on the column. It used to be called EditorControl.
The version I am using the infragistics is Infragistics.Win.UltraWinGrid.v7.1. How could I perform the same by using v.71. Please provide the piece of code to implement.
Like I said in my previous reply, the old property was called EditorControl. Just change EditorComponent to EditorControl. It's the same property. It was changed in order to support components and not just controls, but that doesn't matter in this case since you are using a control, anyway. :)
