I had used Infragistics Version 7.1 with my Visual Studio 2005/2008(VB .Net Windows Forms application). The tool was working fine as we were using the exe.
I recently downloaded the trial version of Infragistics that created a menu in my Visual Studio 2012.
Now we need to make some changes to the tool and unable to use the UltraWinGrid as it says it is not defined.
Dim UltraGridBand Dim UltraGridBand3 As Infragistics.Win.UltraWinGrid.UltraGridBand = New Infragistics.Win.UltraWinGrid.UltraGridBand("Test1", -1)
I am also unable to use the UltraCombo or any other Infragistics Controls. If you could help me on how to update my code to understand the infragistics controls, it would be really great.
Hello Veena,
Thank you for contacting Infragistics Support.
With the installation of Infragistics WinForms you receive a special tool called Version Utility. This tool allows you to easily upgrade solutions to a volume of Infragistics controls. There are three editions of the utility depending on the interface used – a command line interface, an add-in interface and a stand-alone application. Each of these editions are using same core engine and allows you to upgrade a solution, a project and a website.
In order to upgrade your project start the Version Utility, select your project (this step is not necessary if you upgrade a specific project through Visual Studio add-in interface), review the files to upgrade, optionally customize the upgrade and perform the upgrade.
More about Infragistics Version Utility you may find by following the next link http://help.infragistics.com/Doc/WinForms/current/CLR4.0/?page=Win_Upgrading_a_Project_to_Infragistics_Windows_Forms_11.1_(and_above)_Using_Version_Utility.html
Please try to upgrade your project with Infragistics Version Utility and let me know if you need any further assistance.
Hi Mico,
Thank you very much for your detailed mail. I tried installing the Platform/Version Utility and upgraded the project and still I am getting error for the controls under the designer of my project as:
Error 344 Type 'Infragistics.Win.UltraWinGrid.UltraGridBand' is not defined. D:\my_Application\GetData.Designer.vb 26 29 my_Application
I have the visual studio vb .net solution developed in Visual Studio 2005. I changed my servers and do not have the infragistics on my current server that I am using. I remember having Infragistics Version 7.1 or 7.2 and I have used lot of controls in my UI that involves Infragistics like:
Please let me know if I would be able to get the project on track by installing the Infragistics Platform/Dev ToolKit Trial Version. If it is working fine, then we can go ahead with the full version.
Could you please guide me on the steps I need to take in order to get my visual studio solution in working condition. Let me know if you need additional information.
Veena
Thank you very much for your prompt response! Greatly appreciate your help.
I was able to upgrade the project using the steps provided by you and it works. I had to only update the .Net Framework version.
Thanks for your help!
