I have a map picture of OpenStreetMap, I want to know if is possible use as a georeferenced single-tile for xamGeographicMap.
In other words, I want to use a single-tile xamGeographicMap, and when I zoom the tiles must not change, because I have only one single picture.
Thank you
Regards
Hello Max,
Thank you for your post. I have been looking into it and I can suggest you set the XamGeographicMap's BackgroundContent Property to a Image which source is your picture. Please let me know if this helps you or you have further questions on this matter. Looking forward for your reply.
thank you for your reply, I added the Image as backgroundcontent but I can't zoom it...
Max
If you want to be able to zoom the image, you have to create a TileSource server and use the picture there. If you have a restriction to work without internet, you create a local one.
Hope this helps you.
