435
Web tab Height behavior
Hi
I'm having issue with Web tab Height behavior. I have added 8-9 tabs, First ContentTabItem I'm loading as Under Template and rest of other ContentTabItem tabs thru ContentURL.
First tab is loading very fine but rest of other tabs height is not rendering properly. When I switch back and forth then tab height load normally. This I have to do for all the tabs except first tab.
Please let me know what is the problem here
Here is my Sample markup ;
<ig:WebTab ID="WebTab1" runat="server" Width="99.7%" EnableAjaxViewState="False" TabOrientation="Horizontal"
TabLocation="TopLeft" SelectedIndex="0" EnableOverlappingTabs="false" EnableActivation="false">
<PostBackOptions EnableLoadOnDemandUrl="True" EnableLoadOnDemand="true" EnableAjax="true" />
<AjaxIndicator Enabled="True" Location="MiddleCenter" />
<Tabs>
<ig:ContentTabItem runat="server" Text="Summary">
<Template
<% span="">Some Html here --%>
</Template>
</ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="General Data" ContentUrl="../Checklists/IMP1001_GenData.aspx">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="EC" TabSize="50px" ContentUrl="../Checklists/IMP1001_EC.aspx" >
ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="IC" TabSize="50px" ContentUrl="../Checklists/IMP1001_IC.aspx" >
ig:ContentTabItem>
 <ig:ContentTabItem runat="server" Text="Equip" TabSize="50px" ContentUrl="../Checklists/IMP1001_EQ.aspx">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="TPD" TabSize="50px" ContentUrl="../Checklists/IMP1001_TDP.aspx">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="WOF" TabSize="50px" ContentUrl="../Checklists/IMP1001_WOF.aspx">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="IO" TabSize="50px" ContentUrl="../Checklists/IMP1001_IO.aspx">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="Other" TabSize="50px" ContentUrl="../Checklists/IMP1001_Oth.aspx">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="Documents" >ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="P&MM" TabSize="50px">ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="BAP MOC Log" >ig:ContentTabItem>
Tabs>
ig:WebTab>
Parents Reply Children
No Data
