Control Name 2011.1 : UltraWebListbarControl Name 2013.2 : WebExplorerBar
Properties in 2011.1: UltraWebListbar.Group.UserControlUrl
Above, I have mentioned the Control Name in 2011.1 and 2013.2 versions. I need the Replacement properties of WebExplorerBar in 2013.2 for the above mentioned property.
Hello Priyanka,
Thank you for using our forum.
I am glad to hear that you are using our new Aikido controls. About your question, yes currently we do not have such property and there isn't a direct equivalent, although you can use ItemTemplate which purpose is exactly this, to put any asp or custom control into the template and to use it as Item in your WebExplorerBar. You can have a look at the following online samples related to this requirement and also our official documentation.
http://www.infragistics.com/samples/aspnet/explorer-bar/templating
http://www.infragistics.com/samples/aspnet/explorer-bar/property-explorer
http://help.infragistics.com/Doc/ASPNET/current/CLR4.0/?page=WebExplorerBar_Using_WebExplorerBar.html
Let me know if I may be of further assistance.
