70
Deleting commas in Infragistics.Grid
I'm having trouble by deleting number's commas inside columns. I tried the Format() method, which works outside columns but not inside.
Here is the working code to delete commas :
@(Html.Infragistics().Combo().ID("idFilteringIdDeclarant").Format("").DataSource(ViewBag.Entities).ValueKey("EntityNumber").TextKey("EntityNumber").Width("100px").Render())
Here are the columns that don't change when applying Format() method  :
.Columns(column =>
         column.For(x => x.IdLineD).Hidden(true);
         column.For(x => x.IdForm).Hidden(true);
         column.For(x => x.EntityNumber).Format("").Hidden(false).Width("5%");
         column.For(x => x.ReferenceAIEA).Hidden(true);
         column.For(x => x.Processing).Hidden(true);
         column.For(x => x.NbArticles).Format("").DataType("number").Hidden(true);
         column.For(x => x.NuclearMaterial).Hidden(true);
         column.For(x => x.Mass).Format("").DataType("number").Hidden(true);
         column.For(x => x.WasteOrigin).Hidden(true);
         column.For(x => x.ENDAN).FormatterFunction("lookupCountry").Width("75%").Hidden(false);
         column.For(x => x.DestinationAddress).FormatterFunction("lookupAd").Hidden(true);
         column.For(x => x.ExportDates).Hidden(true);
         column.For(x => x.Comments).Hidden(true);
         column.For(x => x.AdminComments).Hidden(true);
         column.For(x => x.Status).Width("20%").Hidden(false);
         column.For(x => x.canBeDeleted).Hidden(true);
Do you know any solution to counter this ? I really need to have a specific format (displaying 4 numbers without a comma)
Thank you very much,
Parents Reply Children
