UltraWinGrid Version: 11.1.20111.2111
I have a small UltraGrid that has different types of fields (e.g., text, numeric, drop downs, dates). Here's the situation:
ugActionCycles.DataSource = _dsActionsugActionCycles.DataBind()
ugActionCycles.Rows.Band.Columns("LastAction").EditorComponent = udteLastActionugActionCycles.Rows.Band.Columns("NextAction").EditorComponent = udteNextAction
For example, referring to the graphic below, I change the Type to another value, uncheck the Repeat, and then change either the Last or the Next and the Type and Repeat reset to their original value.
What am I doing wrong? Probably super simple but I've been wrestling with this for almost a day now. Not fun.
You will get the default values field in UltraGrid cells if the corresponding column has a default value and the row is submitted with null. So based on this and the exception which you mentioned it seems to me that somehow current edit row was deleted and new row was added on its place. Also I believe that this was did because of some validation logic. If you are able to isolate this in a simple sample which you could post here I will be glad to investigate this further for you in order to find the exact reason for this issue.
I am waiting for your feedback.
