I have value stored in database like 'MM/DD/YY' this format , but when I tring to get the value in WebDatePicker it retriving as " 'MM/DD/YYYY'.
EX : value stored in DB as '12/02/15' , WebDatePicker showing it as '12/02/0015'.
Please help me in this issue.
Thanks in advance.
Venkatesh
You could control the display format using DisplayModeFormat="MM/dd/yy as well as the edit mode if required like EditModeFormat="MM/dd/yy. You could refer to the following forum thread for more details.
http://www.infragistics.com/community/forums/t/51509.aspx
Official documentation:
Edit and Display Mode Formats in WebDatePicker
The standard Date Time Formats String could be found at: https://msdn.microsoft.com/en-us/library/az4se3k1(v=vs.110).aspx
Please let me know if you require further assistance.
